 Pages:  1    3  ..  8
Author: Subject: 4efte vs. 4age
jastunna1987
Mood: good
[*] posted on 28-6-2003 at 01:33 AM
4efte vs. 4age
hey guys, later on i would like a more powerful engine fo my cel. what would u guys prefer. i like the 160hp from the 4AGE, but everyone always talks about the 4EFTE. which ones is more upgradeable and has the more potential for hp? I also know the 4AGE is a lil bit more expensive. thanks
13-Gochi
Mood: rollin' in a Dub
[*] posted on 28-6-2003 at 09:37 AM
depends on if you want to start with an all motor or boosted setup, 20 vavles will beat 4EFTE's in stock trim.
1994 Tercel \"Naomi\" R.I.P.
2001 Jetta 1.8T \"Beatrix\"
jastunna1987
Mood: good
[*] posted on 28-6-2003 at 12:58 PM
that is what i thought, but which one would u say will have the most potential for hp wit upgraded internals, a turbo, and a few other things. and the 4age is kinda pricey, i think i could push out more than the 4efte can, if they had the same upgrades. also, which one has more upgrade parts. i dont think i've seen to many sites with 4age and 4efte engine parts.
Iceman_Chapman
Mood: Dismayed
[*] posted on 28-6-2003 at 01:37 PM
4agze
Down but not out...
20VALVER
Mood: do unto others
[*] posted on 28-6-2003 at 06:40 PM
207 MPH 4AGE try that with 4efte?
http://www.bobnorwood.com/The%20Fastest%20Little%20Sports%20Car%20i...
13-Gochi
[*] posted on 29-6-2003 at 12:05 AM
well if you wanna get technical, the 4AGE only has .3 liters on the 4E motor. You can incrase the displacement of the 4E to about 1495cc by modifying the stroke to say.... 82 mm. don't think theres much you can do to the bore though the cylender sleves are razor thin as is. 4AG's will make power, but after you open them up. 4E's will make power with bolt-ons and stay safe, but their max power on the factory guts is limited. It's the truth-saint-
jastunna1987
Mood: good
[*] posted on 29-6-2003 at 12:29 AM
thanks dawg. i was going to get a 4age, but those r more expensive. just one more question. do u think i can get the 4e to 200hp witout NOS? thanks
13-Gochi
[*] posted on 29-6-2003 at 01:23 AM
just about anything besides the CT-9 turbo will get that engine abouve 200 hp. T3, T04, T03, T3/T4, 16G, CT26?, but you'll need more than a turbo.
What trim you lookin at. what A/R are you getting... I wouldnt waste my monet on anything less than a .48
[Edited on 6/29/2003 by 13-Gochi]
jastunna1987
Mood: good
[*] posted on 29-6-2003 at 01:42 AM
i am in the process of makin up my mind. i might get the 4e cuz its cheaper. but i want ALOT of power. what would u suggest for this engine. i want atleast 225hp
jastunna1987
Mood: good
[*] posted on 30-6-2003 at 02:08 AM
i think im just going to go with the 4AGE and probably throw in a little turbo to get me at 230hp.
Xero
Mood: cranky
[*] posted on 1-7-2003 at 07:47 AM
now i cant say for sure, but... i think the 4age is difficult to turbo as due to the high compression ratio.. same deal with the new celica GTS.. on the other hand, on BYP's website, you can find what looks like an 80's tercel hachback hailed as "an Acura Integra GS-R Killer! This 1.3L boast 250 WHP at 20 lbs.. and that's on the stock block with minor upgrades" <- copy and paste. ^_^
also, the 4e-fte is a direct drop, whereas the 4age requires custom engine mounts, and you have to replace the front axle as it wasnt designed to handle 160hp. (this last statement was brought to you by a foggy memory of a post long ago, and the info therein may not be correct. ^_^)
of course, if im wrong anyone, please correct me so we can all learn from my ramblings. -bouncy-
[Edited on 1-7-2003 by Xero]
Dracopjs1230
Unregistered
Posts: N/A
[*] posted on 15-7-2003 at 03:00 PM
4age 1.6 20 valve beats 4efte
wanna see what a boosted 20 valve 4age can do....
http://www.bentrodbob.freewebspace.com/
300 + HP,
4efte can't do it
4AGE can.... N E questions
dracopjs
PS the 4AGE 20 valve is cheaper than the 4EFTE check EBAY
Vtec Hunter
Mood: Above 0PSI
[*] posted on 15-7-2003 at 07:01 PM
Gimme a break
The BYP 4efte is doing over 300 at the fly on all stock internals, and it's doing it a hell of alot cheaper than this guys car. And with slicks the 4efte Tercel will prob. run 12's this guy hasn't cracked 12's yet with a 1.6. If you're looking at spending ALOT MORE MONEY , then yes...get the 4age but if you want to spend ALOT LESS MONEY for 12-13s then get the 4efte. 300hp is doable and you really don't need any more than that for a street car.
V_Hunter_
Dracopjs1230
Unregistered
Posts: N/A
[*] posted on 15-7-2003 at 08:01 PM
any links//// didn't think so....
How much is a 4EFTE pushing 300 HP installed in a Tercel? Let's do the math....
Full stock (145 HP) from BYP....2000
1.6 20 Valve 4AGE (160 HP)....The way i have priced it.....around 2500 (1000 Parts, 1500 install)
If you have a link for a Dynoed 4EFTE w/300 HP now is the time to show it.
Otherwise 1.6 4AGE 20 v has the MOST potential for power, dollar for dollar.
TurboTercel1992
Mood: Horrid
[*] posted on 15-7-2003 at 08:06 PM
OOOH OOOH OOHH!!!!!! Waves arms around......heh heh.
TAVO is a thief. Drugs are bad, mmmkay.
Apparently, my signature offended the admins.
Truth hurts.
 Pages:  1    3  ..  8
