Author: Subject: 98 Tercel Neutral Switch Question
lildwayne14
[*] posted on 30-5-2018 at 03:09 PM
Good day guys. I am in the process of completing my auto to manual transmission swap.
Took out the automatic transmission yesterday and Im looking to bolt the manual trans in later today.
My question is which wires do I bridge to let the ecu think that the car is in Park or Neutral so that it will start.
Im still running the stock automatic ecu for now.
[Edited on 30-5-2018 by lildwayne14]
lildwayne14
[*] posted on 19-6-2018 at 03:02 PM
Bump
lildwayne14
[*] posted on 26-6-2018 at 12:40 PM
so i figured it out and thought Id share in case any one came across the same thing. The picture below shows the harness connection that runs to the neutral switch for an auto transmission as well as which wires need to bridged. I believe the other two connections on either sided of the bridged wires are for the reverse switch but I haven't ran and tested those yet but will post when i do.
