Author: Subject: 4efte MAP sensor compatability
chrisagrant
[*] posted on 4-5-2018 at 11:57 PM
So I did ANOTHER 4efte build and for some stupid reason instead of doing a stand alone engine management I decided to use the old greddy emanage and a custom wire harness. PROBLEM is that the Map sensor appears to be bad. I have scoured hi and low for a direct replacement... its tough. Also tring to find good data on what supra MAPS that I MIGHT be able to get could be compatable.. also tough. The GM map works OK but not great, and probably definitely not great under high boost tuning.
Whos got a MAP I can buy, or who knows for SURE what MAP replacements. Ive scoured the data on here and have gone cross eyed, can anyone point me in a new direction?
AlbertaBeef
Mood: Time for upgrades!
[*] posted on 6-5-2018 at 12:05 AM
Original for the 4efte MAP is Toyota Part #: 89420-10010
FYI - Only the MAP sensors with either a green or orange sticker work.
As for other toyota parts, you can use a MAP from any of the following:
3sgte mr2 turbo
2jz-gte supra turbo
4agze mr2 supercharged
Hope that helps! Good luck!
[*] posted on 6-5-2018 at 06:24 PM
If you still have problems finding one hit me up Chris.
I always keep a few within reach :deal:
chrisagrant
[*] posted on 8-5-2018 at 02:12 PM
Sounds good thanks guys, I bought what should be a 2jz-gte supra turbo one, but lets see if it works. If you think you can source one, HMU with a price!
[*] posted on 10-5-2018 at 02:18 PM
That should work just fine. :deal:
