Author: Subject: Cruise Control
tbear
[*] posted on 24-3-2018 at 12:59 PM
Cruise Control
Hello Everyone,
I just put together my Tercel and its running great. Some little modifications made. In the process of taking out the instrument cluster out of the dash, I noticed that there is a light for cruise control. It is the most bottom indicator light below the seatbelt warning.
Anyways, curious, did the Tercel (4th generation) come with a cruise control system? Possible to retrofit one in?
Cheers.
[*] posted on 25-3-2018 at 06:34 AM
I've seen this a few times for Paseo. Here's a helpful link of the cruise control lever on sale
https://www.google.com/search?q=toyota+paseo+with+cruise+control&...
And orientation images on this parts site
[Edited on 3-25-2018 by thirdcel]
[*] posted on 25-3-2018 at 12:52 PM
Strangely enough, there used to be an aftermarket cruise available for the 92-95 Paseo, which I have. Custom brackets and wiring. Clean enough install that Toyota techs would look at it and ask me about it.
I wonder if that kit could be installed in a Tercel... :dunno: I am sure the brackets would not be compatible.
I have an extra used kit in my garage that I bought off Madcat on here :twocents::twocents::twocents:
[Edited on 25-3-2018 by thoughthard2comeupwithths]
