Author: Subject: 4thgen paseo 5efe in 5th gen tercel?
britishkid1
[*] posted on 1-2-2018 at 07:55 PM
hey guys
just curious if anyone has put a 4th gen 5efe engine in a 5th gen tercel
i have 4th gen engine trans ecu and wiring harness
thanks
britishkid1
[*] posted on 16-12-2018 at 04:30 PM
can anyone help me out
thank you
[*] posted on 21-12-2018 at 09:53 AM
Nope, I've never seen it. The ignition system is fairly different. They changed from a distributor system to a coil pack waste spark setup.
britishkid1
[*] posted on 28-12-2018 at 03:36 PM
Even if I gave the wiring harness and ecu to go with the 4th gen engine
[*] posted on 29-12-2018 at 03:07 PM
If you have the wiring harness and ECU it should work or just swap to the DIS head and use your existing wire harness and ECU
britishkid1
[*] posted on 13-1-2019 at 08:59 AM
My problem is the bottom end. Pretty sure the oil rings are toast.
