 Pages:  1  2    4  5
Author: Subject: Project Sneak Up
lildwayne14
[*] posted on 5-12-2017 at 12:37 AM
Quote: Originally posted by Italianjoe1
I've debated doing a stealth/small boost setup on my daily '97 when I get the turbo 5e car back up, i have a bunch of spare water to air cooling parts from my Cobalt days, and could run a recirculated WG and BOV to keep the car sounding a looking very stock outside, yet have 200hp.
Problem is, I LOVE the turbo car noises, and you aren't gonna beat anybody with a 200hp car anyway. So the daily will probably stay stock powerwise, while I spend my time trying to get closer to 300hp out of my Paseo.
I agree with you on the turbo noises which is why im thinking of only making the appearances be stock meaning it only looks stock but if you pop the hood its a different story.
My aim is not to beat everyone because as u rightly said 200hp is nothing these days but i just want to be able to make people look twice when they think they would pull away from me but still see me keeping up lol.
what plans do you have for the paseo?
[*] posted on 5-12-2017 at 02:13 AM
Quote: Originally posted by lildwayne14
I like the construction of the brace and should enhance handling in addition to the other braces I plan to add.
You mention a rear strut brace. More info on the topic here:
http://board.tercelonline.com/viewthread.php?tid=38999
http://board.tercelonline.com/viewthread.php?tid=37937
lildwayne14
[*] posted on 5-12-2017 at 09:39 AM
Thanks will have a read
lildwayne14
[*] posted on 5-12-2017 at 09:44 AM
I was able to do the strut brace install over the weekend. Here is how it turned out. Nothing fancy with the install, remove two nuts install the brace and reinstall the nuts.
More pics here: https://epbible.weebly.com/blog/strut-brace-install
[Edited on 5-12-2017 by lildwayne14]
[*] posted on 5-12-2017 at 04:28 PM
I just wanted to say that your engine bay could definitely use some loving with some purple power :lachen: but the strut brace does look nice!
[Edited on 5-12-2017 by mycars12]
[*] posted on 5-12-2017 at 09:24 PM
The paseo is getting my turbo 5E setup from my tercel which was crashed. Megasquirt, Subaru TD04L turbo, E85, simple stuff. Makes mid 200s on 24psi, I'm gonna add some more parts when it goes into the Paseo, plus the car will be gutted and more of a racecar than the Tercel body was.
lildwayne14
[*] posted on 6-12-2017 at 12:18 AM
When I posted it i was thinking of writing pardon the engine bay lol. Its not really dirty its just that its winter here and i had to spray that stuff in it to keep the rust away. It looks different in the summer
lildwayne14
[*] posted on 6-12-2017 at 12:19 AM
sounds good. Did you do the wiring for the mega squirt yourself. Im thinking about that route but not sure yet.
[*] posted on 6-12-2017 at 04:10 PM
If you browse this forum someone literally has a whole 15 pages dedicated to running his megasquirt in his 5th gen tercel. Some canadian dude with a black 5th gen.
[*] posted on 6-12-2017 at 07:38 PM
No, I bought the car from a member on here, running on the MS, but then the engine blew and all other sorts of stuff fell apart. I haven't had to re-wire it, but I will have to change some things when I put it in the other car now. It uses the majority of the stock harness though, wouldn't be too bad of a project if you're mechanically inclined.
lildwayne14
[*] posted on 10-12-2017 at 05:24 PM
Springs are here.
I was looking for some springs that were not to expensive but would still give you some amount of performance when needed and I came across the Vogtland spring.
Appearance wise they dont look too shabby, I hope they perform just as well.
More pics: https://epbible.weebly.com/blog/vogtland-tercel-springs
[Edited on 10-12-2017 by lildwayne14]
lildwayne14
icon_pix.gif posted on 2-1-2018 at 08:39 AM
I haven't posted in a while as I was busy over the holidays with family and Christmas stuff.
I was able to pick up a TD04 the other day for my project.It seems to be in great condition as it has no signs of excessive oil and no sign of shaft play.
Not going to go too much into detail as to why I chose this turbo but if really want to know check out the link below. You will also find more pics there too.
http://epbible.weebly.com/blog/baby-boost-td04-turbo
Paseobeater
Mood: Red Paseo Trac car
[*] posted on 22-1-2018 at 04:18 AM
springs will be good enough for your struts... it's not like coilovers but it will do the job better than OEM springs for sure!
Put your wheels up in the air
lildwayne14
[*] posted on 22-1-2018 at 01:46 PM
Thats what im hoping. :2thumbsup:
lildwayne14
[*] posted on 7-3-2018 at 10:16 PM
Been so busy that i havent really gotten around to posting some of what i have been up to.
Got some brake shoes as I am not yet able to do the disc conversion just yet.
 Pages:  1  2    4  5
