Author: Subject: Water Pump and Seals
Outdoorsman131
[*] posted on 14-10-2017 at 08:34 AM
Yo everyone. Having some issues locating the water pump inlet pipe o-ring which presses into the pump housing. Also I'm getting mixed results as to whether or not I should just use liquid gasket or a factory seal for the pump housing to the engine block. Again, parts for that gasket seem to be hard to find as well. I notice some water pumps your can purchase come with one, but majority don't.
If anyone has some actual part numbers that I could hunt down that would be super helpful. I appreciate it in advance!
91Terc
[*] posted on 30-10-2017 at 05:10 AM
You have to use the O-ring. I have seen them on ebay. you can get them at local parts stores as well. Most good kits like those form Toyota come with the O-ring.
