Author: Subject: Issues after engine swap
Medic11c
[*] posted on 27-9-2017 at 04:43 PM
I finally got around to putting my new engine in. I also relocated the battery to the trunk (2/0 welding wire for positive, 2/0 and 4 ga ground to chassis and (2) 2/0 ground straps to the engine block). I have the the factory positive wires going to a distribution block connected to 2/0, also connected a 4 ga wire to starter and a separate 4 ga to the alternator.
The car starts (after an fun game of your starter is shot:censored:) and runs well, but the idle is running around 1500 to 1800. I cleaned the IAC and TB with no change, checked the tps output with DMM and is in spec, can't find any vacuum leaks not sure where else to look.
The other problem is getting odd error codes like p0120, an igniter code (can't remember the number) ans a vss code (speedo now works whenever the hell it feels like it). Read that this might be due to the ecu going or at least the capacitors (checked them and they look ok no bulging or leaking). Any ideas?:censored:
[Edited on 28-9-2017 by Medic11c]
96 Tercel Coup
[*] posted on 27-9-2017 at 08:27 PM
What motor? Year of the car swapping into? I would try the idle air screw to bring it down a bit. Mine has an issue where the cable is binding and it sticks sometimes with my 4e swap in a 94 tercel.
Good luck.
2009 Pontiac G8 GT *sold*
Medic11c
[*] posted on 28-9-2017 at 12:54 PM
Oops, it is a 96 tercel 5efe.w
96 Tercel Coup
Medic11c
[*] posted on 6-10-2017 at 07:05 PM
It must be the IAC, if I plug the hole at the base of the throttle body that leads to the IAC idle returns to normal (well about 1000 rpms). I have burped the cooling system so don't think that is the issue. I even switched the IAC from the old motor (that was working fine before the swap) over with same effect.
[Edited on 7-10-2017 by Medic11c]
96 Tercel Coup
91Terc
[*] posted on 30-10-2017 at 04:53 AM
This one is common, the new throttle body gaskets do not cover the bypass port behind the tps sensor and you have a vacuum leak. If you jam you little fingure into the gap behind the tps at the gasket you will find thew leak.
