Author: Subject: Headlight issue
EL44_5spd
[*] posted on 23-7-2017 at 10:02 PM
Headlight issue
Hey guys,
My passenger side headlight does not light up when switched on to low beams but does come on when I switch to high beams. The drivers side lights works normally however. Would this be a switch issue or grounding? Any help would be appreciated, thanks!
-josh
[*] posted on 24-7-2017 at 05:49 AM
Check the bulb.
EL44_5spd
[*] posted on 26-7-2017 at 05:56 PM
Okay will check it out.
