Author: Subject: 5EFE Crankshaft and Engine Questions
huckmubb
[*] posted on 6-5-2017 at 08:17 PM
Ok, so I have a 1992 Turbo Tercel with megasquirt. I am going to put together a 1st generation 5EFE that I got out of an automatic Paseo.
1.) On a 1st generation 5EFE with a crankshaft stamped 5EFE, are the automatic and manual crankshafts the same?
2.) Can I simply bolt my 3EE flywheel onto the 5EFE automatic crankshaft?
3.) Does anyone know what the compression ratio would be with a .120" thick head gasket on a stock 1st Generation 5EFE engine?
[Edited on 7-5-2017 by huckmubb]
93 Tercel. 3E-E stock block, crank, rod, pistons, with 5EFE Paseo 1st Gen Head, 0.019" stainless steel shim head gasket, 8.8:1 compression, IHI Turbocharger, model RHB5 VJ5 from Mazda GLX. 8 PSI boost. Supra 295cc Low Impedence yellow top ultra fast injectors, Home soldered Megasquirt I, Version 3.0 PCB stand alone fuel and spark management. Saab turbo spark module, stock Tercel coil, stock 5EFE distributor. 10mm stainless steel core silicone plug wires, 15" Montegi R116 wheels, Intercooled, Custom high flow 2 1/4" sink trap turbo manifold, custom 2 1/4" welded down pipe with separate wastegate pipe. 2 1/4" exhaust system with solid steel flowmaster muffler. Estimated 170HP at 6600 RPM. http://www.ritalie.com/tercel
