Author: Subject: Which one?
[*] posted on 5-5-2017 at 08:48 PM
do not worry about it. I ordered for KYBs
The only thing I think that relates to is the rubber isolator rings they give you to put between the sleeve and the damper body.
my first set of staggs I had to cut an extra crown of metal off the front struts to allow the sleeve to slip over. the second set I did not, it was redesigned
[*] posted on 5-5-2017 at 09:19 PM
I have been watching vids and reading about ground controls, and I think this is the ticket. I hope they work with gen 3 tercel. Thanks for the advice malibuguy.
Ps
I sent them an email to check the compatibility with the gen 3.
[Edited on 6-5-2017 by Geewhiz55]
titaniumADRIAN
[*] posted on 6-5-2017 at 12:54 AM
On my 95 Tercel I have 4th gen KYBs(40% stiffer than OEM 5th gen) with fake ground control sleeves and eibach springs 400# front 550# rear. front blackhawk OEM sway bar, homemade adjustable rear sway bar.
car handles great, rearend is loose but loose is fast.
Here is a video of my second fastest run during the Florida Autocross Championship, which me and my tercel took 1st place in FSP class
https://youtu.be/LOiPGtwR4V4?t=15s
[Edited on 6-5-2017 by titaniumADRIAN]
[*] posted on 6-5-2017 at 07:14 AM
Ha! I've watched this a few times already. Congrats on taking first place. I did notice that it handled really well and seemed to have little body roll.
[*] posted on 16-5-2017 at 08:37 PM
Just a little update and in need of a little more help.
So I've been in contact with Trevor at ground control. He said he did'nt know if the 92-99 years would work for me. He is wanting to build me a ground control system or find me a solution. He did ask if I knew of any adjustable shocks and struts that work on my car. That's the help I need. The one thing I do know for sure is that the rear shock mounting point on the rear axle is lower than the later years. A couple of inches lower.
[*] posted on 16-5-2017 at 09:11 PM
Ive seen people using later stuff on them just fine
titaniumADRIAN
[*] posted on 16-5-2017 at 11:39 PM
Look for Toyota starlet struts and and shocks
they fit tercels and are adjustable
here are some part #s
Koni sport
front 8641-1214SPORT
rear 8040-1216SPORT
Bilstein B6
front 34-050194
rear 24-014991
[*] posted on 17-5-2017 at 09:39 AM
Konis are cheaper than the bilsteins
[*] posted on 17-5-2017 at 04:09 PM
Thanks for the leads.
[*] posted on 17-5-2017 at 06:26 PM
I my have found some Koni s and bilstiens.
[*] posted on 17-5-2017 at 08:47 PM
We would have to special order them from Holland $549 set of 4 F&R. Adding to a seafreight container takes 8 weeks or so
They can also add to a airfeight shipment which then takes 2-3 weeks for $50
Mark
To order, just call, fax, or click here:
https://ssl.shox.com
Use generic quote number 8761616
We look forward to hearing from you!!!!
SALES DEPARTMENT,
WWW.SHOX.COM
11464 Pinehurst Drive
Lakeside, California 92040 USA
800-683-2890
619-444-9766
Fax 619-444-8261
sales@shox.com
Thats a quote I received last month :lachen:
For the koni's of course
[Edited on 18-5-2017 by mycars12]
[*] posted on 17-5-2017 at 09:36 PM
Thanks a ton My cars!!
Is this a quote you got from shox.com that you are passing along?
The price is about $100 less than what I found.
titaniumADRIAN
[*] posted on 17-5-2017 at 11:20 PM
you can get the set of koni's on ebay for $519 w/ $18 shipping
[*] posted on 18-5-2017 at 05:39 AM
Yeah. Its a quote that I had recieved and just thought of sharing it :lachen:
It is 549 but free shipping. It takes a while for free :blah:
I have been on the fence of getting full coilovers or getting konis with some sort of ground control setup.
[*] posted on 18-5-2017 at 03:03 PM
Thanks titanium, those are the ones I found.
I didn't convert to US dollar.
Thanks my cars for the "share".
I sent Trevor over at ground control another email about the found Koni s.
Waiting to here back on cost since all I would need are his coilover collar assembly and his springs.
I'm thinking this is the way to go.
[Edited on 18-5-2017 by Geewhiz55]
