Author: Subject: Help! Harness/ECU/Everything issues getting this running ...
AlbertaBeef
Mood: Time for upgrades!
[*] posted on 1-5-2017 at 06:50 PM
Quote: Originally posted by GT_REVVA
Well I'm going to go out on a very STRONG limb and say BYP didn't screw up ANY harness
I made all the 4E harnesses for BYP so I GUARANTEE no mistakes there
ALL harnesses are made from harnesses provided BY THE CUSTOMER....Which means what you have on your engine there is a product of the harness you sent me from your car as well as whatever you got with your motor
Now before you go shooting from the hip, you did say you were on lots of prescription narcotics, so take that factor into consideration
No a 3EE ECU will NOT operate a 4EFTE motor, no matter if they both have 26/16 pin outlets :doh:
Buy a 4efte ECU
You are correct, sir. I apologize if it sounded like I was accusing you/BYP of making a mistake ... It would only have been the case if the ECU connector was different ... and honestly I didn't investigate fully the difference between the ECU's until AFTER I made my post.
And Yup, I am buying a 4E-FTE EP82 green label ECU ... assuming I can find one.
AlbertaBeef
[*] posted on 2-5-2017 at 12:50 PM
Update: Kind TO member Horse2000 is sending me an ECU from Florida, yay!
BTW why ARE there so many TO members in Florida? Seems like the epicenter of 4E-FTE swaps for some reason ...
AlbertaBeef
[*] posted on 4-5-2017 at 07:27 PM
Update: Got the ECU. Got the car running. Biggest issue atm is that it's running rich, started a new thread: http://board.tercelonline.com/viewthread.php?tid=54348
