Author: Subject: Rear tires rubbing issue
Father Kaiii
icon_help.gif posted on 19-3-2017 at 01:00 AM
I just bought some 15x8 0 offset rims with 195-50-15 tires and the back keeps rubbing and chomping away on my tires :( I was thinking maybe fender rolling might help or stiffer springs? I just need some advice... plus it's weird to me that the back is wider then the front.
Never drive faster then your guardian angel can fly
[*] posted on 19-3-2017 at 07:26 AM
The wheel might be the wrong offset and they have moved the tire too far out and that might be one of the reasons the lip is catching the tire.
You can roll the fender and it will help. Are you're rear shocks in good health?
Father Kaiii
[*] posted on 19-3-2017 at 01:15 PM
True, I'll try swap them around to see. My shocks are ok, What camber kits can I use?
[*] posted on 20-3-2017 at 01:12 AM
Get some wheels with an offset that is more ideal.
Stiffer springs are just a band-aid for your issues...
Father Kaiii
[*] posted on 21-3-2017 at 01:40 AM
Around what offset? Cause I was thinking on the positivesp
Father Kaiii
[*] posted on 25-3-2017 at 02:56 AM
Finally traded wheels with my friend and it sits pretty nice to me, offset is much better. https://www.instagram.com/p/BSCw30MDxgn/ Sorry I don't know how to post a pic through my phone. :doh:
[*] posted on 25-3-2017 at 04:16 PM
Father Kaiii
[*] posted on 25-3-2017 at 08:07 PM
Thank you so much for doing that :pepper:
