Author: Subject: Turn signal switch,..Paseo/ Tercel
clau069cr
icon_help.gif posted on 27-2-2017 at 01:20 PM
Hi Guys, I want to know if anyone knows if the turn signal switch. w / o cruise control from Paseo 92, is plug and play, in a 91 tercel without airbag?
Does not require any modification?
Is the Part Number: 84310-16500 ??
[*] posted on 27-2-2017 at 02:00 PM
As far as I remember, that whole stalk assembly is plug and play. Both being non-airbag.
The intermittent wiper feature on the Paseo stalk will function as well.
clau069cr
[*] posted on 27-2-2017 at 02:06 PM
Thanks thoughthard2comeupwithths, I'm going to buy it online, and I did not want to go wrong. Thank you very much for the tip.
The part number will be 84310-16500 ??
[*] posted on 27-2-2017 at 02:12 PM
As for part number, I am unsure.
You might want to wait for someone else to chime in to make sure I'm correct though. I have sold used ones in the past from non-airbag Paseos to members to swap on their Tercels. Some higher end Tercels had the same intermittent wiper feature as the Paseo.
clau069cr
[*] posted on 27-2-2017 at 02:24 PM
Okay, thanks buddy for your help :2thumbsup:
clau069cr
[*] posted on 28-2-2017 at 09:14 AM
Hello guys, it looks like I do not find turn signal switch OEM from Paseo 1992; All the dealers I contacted told me that, item is no longer available Do any of you know where I can buy it online, that switch? please..
https://imageshack.us/i/p75T8T0xj
[Edited on 28-2-2017 by clau069cr]
[*] posted on 28-2-2017 at 12:52 PM
Used, possibly on eBay or on here, might be your only choice.
If you are not in a hurry, I might be able to get one from a junkyard, but who knows when I will make it down again. It's 188 mile round trip, so I have to have to make it worthwhile to cover gas costs. The next junkyard adds another 98 miles to the total trip.
I have a mint condition one in my personal collection that I was going to swap at some point into my Paseo, and sell my current unit. When the swap happens is unknown. Where it's located in my stash is unknown also :dunno:
[*] posted on 28-2-2017 at 07:57 PM
Do you have to have a paseo one? I have a good working assembly in my 91 terc that is crashed, I can remove it and sell it.
clau069cr
[*] posted on 28-2-2017 at 10:51 PM
U2U
[*] posted on 1-3-2017 at 01:32 AM
FYI... if you want the intermittent wiper feature that the Paseo has, only a few Tercels have that feature...
