Author: Subject: 4E-FTE Battery light barely coming on
1.3L Turbo Tercel
[*] posted on 9-2-2017 at 09:51 PM
Hey guys!
So lately I've been noticing "early in the morning, I work at 4am" That under high rpms a good 5000+ the battery lights faintly comes on, I've also been noticing I'm only boost to 6 tops 7psi, I don't know if that's my ebay boost gauge or because the spark plugs aren't getting enough juice to ignite the fuel, I do have a cigarette lighter voltmeter plug in and it drops form 14.6v to 14.5v when the light starts dimly showing up
Any input or suggestions are much appreciated!
I have considered a new alternator but I don't know if I want to spend the $70 yet if its not the problem
Thanks! :waving:
-Tyler
96 Tercel with Glanza swap
T25 Turbo upgrade
Top Mount
Paseo sway bar, brakes and gauge cluster swap
[*] posted on 11-2-2017 at 02:11 PM
Check your grounds, then have the battery and alternator checked. Then go from there
Member Is Online
[*] posted on 11-2-2017 at 06:35 PM
Sounds like a ground issue, the main engine ground is part of the circuit for that charging indicator, and can affect other PCM things like boost if it's still controlled by the stock computer.
If your voltage at the outlet is 14, there's no reason the light should be on at all. Gotta troubleshoot the wiring first.
1.3L Turbo Tercel
[*] posted on 8-3-2017 at 02:25 PM
Thanks for the info guys, so I have a ton of grounds, my alternator was tested and it's good and I just got a new battery so all that is good from what I know unless my grounds are rotted out... BUT Now the actual dash lights are flickering and going dim -_-
T25 Turbo upgrade
Top Mount
