Author: Subject: Acis manifold
[*] posted on 26-11-2016 at 02:21 PM
Acis manifold
Does anyone know if an acis manifold would work on a gen 1 paseo?
Is it a plug and play? (I'm guessing not)
Is there a huge up side if going turbo or is the regular manifold ok?
Advice?
Thanks
[*] posted on 26-11-2016 at 09:33 PM
Not exactly plug and play, you need the controller for the switchover, easiest way is to use a window switch and set it for the rpm where the long runners stop making more power than the short runners.
Main gain is cyl filling via resonance, not nearly as much of an issue under boost. There was some dyno info on it back in the day, it's here on the forum somewhere. The ACIS does work on a turbo car, but the gains aren't as pronounced as on an N/A car.
[*] posted on 26-11-2016 at 09:52 PM
Thanks again Italian.
I did find some info on here and it's kind of what I was thinking too.
( n/a benefits more )
turbo confustion
Mood: turbo
[*] posted on 30-3-2018 at 08:11 AM
Acis..turbo
Thanks for the replies they prompted me to reread the acis switching thread with Hoodey's dyno charts. Looks like it does help the bottom end power although found it hard to deal with kilowatts and Newton metres. Anyways I'll give it a try and try to get a dyno runs of both. horsepower and foot pounds make more sense. Thanks for the help!
