Author: Subject: squeek
britishkid1
[*] posted on 29-4-2016 at 10:23 PM
squeek
hey guys.
Wondering if i could get your guy's help and insight on a problem i'm having. The front right of my 94 tercel started squeeking and its driving me crazy. Here is my setup if it helps.
A month ago I installed kyb gr-2 shocks all around. Apex lowering spring and kyb strut mounts all around. Only thing original is the spring top hat thats installed below the strut mount in the front.
If you guys could help. very appreciated.
Thanks
[*] posted on 29-4-2016 at 10:52 PM
It could be the spring coils rubbing on each other...
[*] posted on 29-4-2016 at 11:36 PM
when the spring compresses, it kinda twists into the top hat... you could add a bit of grease between the spring & the rubber bushing... or spray some belt dressing lube up in there...
just spitballing...
