Author: Subject: Block heater
tbear
[*] posted on 4-1-2016 at 12:15 AM
Block heater
Hi everyone,
It's cold in Canada.
...and my Tercel never came with a block heater.
So here I am at the store to order one. $35.
Now... does it go into the frost plug at Cylinder 1 or Cylinder 4 ? Two manuals say two different things. The Toyota dealer had no idea, as they haven't seen a Tercel in ages.
(in other words... does it go into the frost plug near the oil filter, or the one closest to the transmission/oil pressure sensor?)
[*] posted on 4-1-2016 at 01:21 AM
Closest to the belts will keep the heat in the engine.
[*] posted on 4-1-2016 at 09:21 AM
I'd go for a circulating tank type heater like the ones Kats makes. You can get them in much higher wattages for faster warm up times.
tbear
[*] posted on 6-2-2017 at 06:08 PM
Hi everyone, an update of what I have found.
There is a nicely detailed previous post about installing a block heater. I shows to install it into the 35mm frost plug next to the transmission.
http://board.tercelonline.com/viewthread.php?action=printable&t...
BUT... Toyota says it goes into the second frost plug, the one beside the oil filter. That said, that frost plug is 30mm
Now when I went to three different stores, they all insist that the block heater for the Tercel is a 35mm diameter. The only frost plug with a 35mm is the one next to the transmission.
So big question is... does it matter where the block heater goes?
