Author: Subject: 4th Gen Tercel (and some Paseo) stuff for sale
smpte
Mood: What has two thumbs and replaced the entire exhaust system?
[*] posted on 1-8-2015 at 07:06 PM
I have a collection of random odds and ends left over from my swap. All parts are used, removed from a 1994 Tercel unless indicated otherwise. I have pics and more details about pretty much everything on this list, just ask.
All prices are "make me an offer." If the price seems right, you get the part. I'll ship anywhere that USPS delivers; send me your ZIP and I'll get you the shipping options.
Brand new, or opened but unused parts:
  • (SOLD) New Genuine OEM 91-95 Toyota Paseo Accelerator Control Cable Bracket w/ Bolts
  • (SOLD) New GMB Water Pump For 3E or 5E (170-1680)
  • (SOLD) New Evergreen Automotive Head Gasket For 3E
  • New Evergreen Automotive Bag of Gaskets -- Can't figure out what a lot of these are for.
  • (SOLD) Opened Unused Genuine OEM Seal Washer For Cylinder Head Cover (90210-09019) -- 2 available
  • (SOLD) Opened Unused 130mm Exhaust Flange Gasket (brand unknown)
3E-E Engine Parts:
  • (SOLD) Throttle Body, California M/T (22210-11161)
  • (SOLD) Intake Manifold, California Spec (17101-11300)
  • Intake Manifold Stay (17118-11140)
  • (SOLD) Water Pump Housing (16100-19225, but without any of 16110-19105)
  • (SOLD) Thermostat (90916-03046) And Water Inlet Housing (16321-11011) -- The housing is for an A/T car; the radiator hose points to the FRONT of the car.
  • (SOLD) RH and LH Engine Hanger Hooks
  • (SOLD) Water Inlet Pipe (16322-11032)
  • (SOLD) Crankshaft Pulley (13408-11012)
  • (SOLD) Crankshaft Timing Pulley and Guide (13521-11010)
  • (SOLD) Camshaft Timing Pulley (13523-11010)
  • (SOLD) Oil Pickup/Strainer Assembly (15104-11020)
  • (SOLD) Oil Pressure Regulator (15310-10010)
  • (SOLD) Oil Filler Cap (12180-70020)
  • (SOLD) Alternator Pivot Bracket (12511-11020)
  • (SOLD) Oil Filter Union (90404-19007)
  • (SOLD) Spark Plug Wire Clamps, Set Of 3 (not broken, far as I can tell)
  • (SOLD) Engine Rear End Plate (11355-10011) -- Solid and straight, but starting to rust.
Vacuum Parts:
  • (SOLD) Vacuum Transmitting Valve (90925-01099) -- California spec, for throttle opener
  • Vacuum Pipe Assy, California spec -- Rigid tubes that run across the top of the intake manifold
  • (SOLD) 2-way Vacuum Hose Joint (90412-06002) -- 2 available
  • (SOLD) 3-way Vacuum Hose Joint (90413-04005) -- 2 available
  • (SOLD) EGR Vacuum Modulator Bracket (25691-11040) -- Holds the EGR vacuum modulator to the EGR valve
  • (SOLD) Vacuum Hose Union For Brake Booster (90407-51002)
Electrical Parts:
  • (SOLD) 91-95 Paseo ECU, California Spec, M/T (89661-16140)
  • (SOLD) A51202 AM/FM Radio (86120-02130)
  • Vacuum Switching Valve For Fuel Pressure (25860-61020)
  • (SOLD) Vacuum Switching Valve For Throttle Opener (25860-11210)
  • (SOLD) Igniter Module (89621-26010)
  • (SOLD) Coolant Temperature Switch w/ Wire (89427-16100)
  • Coolant Temperature Sensor (89422-20010)
  • Oil Pressure Switch (83530-14060)
  • (SOLD) Radiator Fan Switch (89428-12160)
  • (SOLD) 12V 10W Interior Dome Light Bulb (99132-12100)
Engine Wire Harness Parts:
  • (SOLD) Set of 4 Fuel Injector Connectors -- No wire or contacts, just plastic
  • (SOLD) B+ Alternator Plug and Some Wire -- The big thick one
  • (SOLD) 3-Pin Alternator Plug and Some Wire
  • (SOLD) Plastic Wire Harness Cover -- Runs across the top of the engine, alongside the fuel rail.
JDM Mystery Parts: I believe all of these were on a 1990-1992 Corolla II
  • (SOLD) Power Steering (Vane) Pump Assembly
  • Exhaust Manifold For 5E-FE (probably 17141-11170) -- Has 4 threaded studs that connect to a 130mm J-pipe. Also has a 1-wire O2 sensor which looks a little damaged.
  • 5E-FE Exhaust Manifold Heat Insulator (probably 17167-11220) -- Fits above manifold.
  • (SOLD) Accelerator Control Cable Bracket -- Bolts to the throttle body. I think this is where the A/T throttle cable mounts.
Body/Trim Parts:
  • (SOLD) Front Door Lower Frame Cover w/ moulding -- This is the black plastic triangle piece that is on the outside of the passenger door instead of a side mirror.
  • (SOLD) Set of 4 Matching "DLX" Wheel Covers (42602-16010, with "7959" stamped on the back)
Stuff you probably shouldn't buy used unless you're very cheap or have a specific project idea in mind:
  • (SOLD) PCV Valve (12204-10020)
  • (SOLD) Complete Set of12 Intake/Exhaust Valves, Springs, and Retainers
  • (SOLD) Complete Set of 12 Rocker Arms (13811-10021)
  • (SOLD) Distributor Cap And Rotor (19101-11300) -- about 1,500 miles on them
  • (SOLD) Set of 4 Fuel Injectors (2x 23070-11010, 2x 23250-11090)
  • Accelerator Control Cable Assembly (78180-16320) -- Outer rubber sheath is crumbling at the throttle body end.
  • Scrap Catalytic Converter, California Spec (18450-16420) -- One of the flanges was cut and welded to a pipe, and then later the pipe was also cut.
  • Busted Cardone 31-77443 Reman Distributor for 1st Gen Paseo -- NE pickup has out-of-spec high resistance, resulting in intermittent crank-no-start.
[Edited on 7/15/2018 by smpte]
'94 Tercel, 2-Door STD, Blue Metallic
JDM 5E-FE Engine from a Corolla II
No A/C, Manual Everything, No Clock
smpte
[*] posted on 17-7-2018 at 05:51 PM
Hate to bump my own thread, but I'm planning on scrapping some of the bulkier stuff later this summer. We're down to the dregs, but I want to make sure anybody who might need one of these bits can get it.
As I've come to learn, some of these parts can be rather hard to come by. :2thumbsup:
