Author: Subject: rack & pinion gear ratio
greenseo
[*] posted on 16-2-2014 at 10:38 AM
i just ran into the specification on tercel reference for the steering gear ratio on 1 gen paseo and 5 gen tercel . the steering ratio on the paseo is 15.3:1 and the tercel is 21.8:1 or 17.5:1. i assume that the 21.8 was the manual rack and the 17.5 is with p/s . so my question is there anyone have installed a paseo rack and pinion for a quicker steering ratio? if yes was there any noticeble difference ? :dunno:
[*] posted on 16-2-2014 at 01:24 PM
Actually I did the opposite. Put a Tercel manual rack in a Paseo. I never drove it with the power steering. I made the swap to eliminate headaches. The a/c isn't hooked up as the car has been wrecked and damaged the a/c. Due to this I only run 1 belt for water pump and alternator.
I do not need a second belt to turn a pump
I do not have a pump robbing power
I will never have to replace a leaking hose
No pump to leak or lock up
No pressure on rack to ensure leaks
I have to pull about 15lbs to turn at a stop
I have to pull about a 1/4 of a lb to turn at 15mph
At 60mph turning is almost effortless
Nothing but pros in my opinion.
greenseo
[*] posted on 16-2-2014 at 08:06 PM
well since i dayly drive the car in summer and do some auto-x and would like to try some lapping. i would like to keep the p/s since i tried it for about 2 month and its not very nice in autocross and parallel parking... :P without p/s .
[*] posted on 17-2-2014 at 01:34 PM
I run a manual rack in my Tercel w/ a 4e, which can be alot of effort when parking. I originally had power steering, but overheated it often when running autox.
My LeMon's 96 Paseo runs a power rack, but no pump, just the way MalibuGuy runs his, and haven't had any issues.
1996 Paseo LeMon's Race car (soon to be manual w/ 4e)
2009 Pontiac G8 GT
2004 Pontiac Sunfire 2 Door (DD)
2012 Jeep Grand Cherokee SRT-8
1999 Ford Expedition 5.4
greenseo
[*] posted on 22-2-2014 at 01:57 PM
i wait for an other 92-95 paseo at my local scrapward to check the difference in ratios .
