 Pages:  1    3
Author: Subject: My 5th gen tercel
[*] posted on 8-10-2015 at 02:35 PM
Very awesome and so is the Echo!
titaniumADRIAN
[*] posted on 27-10-2015 at 06:34 PM
So the GRM challenge was this past weekend, the tercel did pretty well 18th place if you dont count the exhibition cars. HERE ARE THE RESULTS
did not do so well in the drags. for some reason I was not getting full advance ignition timing.
great thing was the current SCCA FSP champ was there and I let him drive the car, he said the car has potential to be a front runner in the class.
goal for this year was to get it to the challenge and midpack(check!)
goal for next year is to midpack at SCCA Nationals and top 3 in autox at the GRM Challenge
[*] posted on 28-10-2015 at 04:37 AM
Very HAPPY for the achievements of you and your TERCEL!!!!! Keep 'em rollin'!!!
alf :2thumbsup:
TheDemon
[*] posted on 30-10-2015 at 09:18 PM
congratz man!
- The Demon
94 Paseo 5-speed (WIP)
titaniumADRIAN
[*] posted on 10-4-2016 at 08:38 PM
TERCEL FSP
So I got megasquirt working and ran my tercel today at a local autocross event, the above video is my fastest run.
It still needs ignition tuning.
[Edited on 11-4-2016 by titaniumADRIAN]
titaniumADRIAN
[*] posted on 6-6-2016 at 06:04 PM
got new shoes for the Tercel and wrap them with hoosier race slicks.
https://youtu.be/-KsIrWb3B8o
[*] posted on 7-6-2016 at 12:42 PM
Specs on the wheels and what wheels are those?
btw is that first gen seo seats?
curious as to how you mounted the harness
titaniumADRIAN
[*] posted on 8-6-2016 at 07:02 PM
wheels are Konig Wideopens 15x8 +20mm offset
tires are 205/50 spec miata hoosiers(got them used with 5 heat cycles on them)
yes those are first gen paseo seats. I still have the stock seat belts also. its a 3 point harness mounted on the same bolts as the stock seat belts. 2 in the front then pass the harness through the hole in the seat and bolted to the upper bolt of the rear seat belt.
titaniumADRIAN
[*] posted on 8-6-2016 at 07:45 PM
specs on entire car
Drivetrain:
Blueprinted and rebuilt engine to street prepared rules by me
.040 oversized OEM first gen 5efe pistons
.010 shaved head
balanced rods and pistons, Crank was balanced well from factory
AASCO flywheel
2ZZGE OEM clutch
OBX header
Moroso Spiral Flow Muffler dumped right behind the driver
lightweight crank, waterpump and alternator pulleys
Adjustable cam pulley
A/C delete
5speed transmission with 3.94 final drive
Individual Throttle Bodies from a Triumph TT600
7M-GE injectors
Megasquirt tuned for E-85
13lb lawnmower battery
Wheels, suspension and brakes
Daily wheels Acura Integra LS mesh's w/ Falken AZENIS RT615K 205/50
Race wheels Konig Wideopen 15x8 20mm offset 13lbs each w/ 205/50 Hoosiers
civic coilover sleeves 400lbs front ?500lbs? rear
Tein camber plates
Modified 4th gen tercel KYB shocks
Homemade 75D polyurethane control arm bushings
starlet strut bar
19mm front sway bar from a Tercel Blackhawk
Homemade adjustable rear sway bar
Homemade adjustable panhard bar
corolla calipers with Mx3 discs
stock rear drums
Im sure I forgot a few things Ill update if I remember.
[*] posted on 8-6-2016 at 08:48 PM
Any rubbing problems?
Did you roll the fenders?
titaniumADRIAN
[*] posted on 8-6-2016 at 10:18 PM
Nope no rubbing, no rolling of fenders but with the spring rates Im running there isnt much travel even with the grip of the race slicks the outside suspension doesnt compress enough to rub.
also im running 2 degrees of camber in the front and I centered the rear axle after lowering the car, everything helps but I think the main reason I dont rub with such a wide wheel is my spring rates.
this weekends autox will be at a very bumpy lot so lets see how it does then.
[*] posted on 8-6-2016 at 11:24 PM
those are some stiff spring rates...
from the pic, they look like they would surely rub, though...
nice setup...
titaniumADRIAN
[*] posted on 9-6-2016 at 12:42 AM
thank you,
I still have to adjust the rear sway bar for the race tires, as you can see in the video link I posted the rear bar may be to stiff. the inside rear tire is lifting which is ok but its lifting to fast and equally coming down as fast unsettling the car in the process, think of it this way you are going from the grip of one tire in the rear to two tires to quickly cause the driver(me) to put in additional inputs. the driver with the least amount of inputs around the same course will be the faster driver.
 Pages:  1    3
