three more...
the window winder mechanism from a 1st gen Paseo fits the 4th gen Tercel, works perfect...
the fuel door/trunk release lever from a 1st gen Paseo fits the 4th gen Tercel, but you'll still need a 4th gen Tercel door without the lock-hole...
the cables are the right length, though...
the mirrors from a 1st gen Paseo will fit the mirror housing of a 4th gen Tercel... they are a little narrower, but longer, and give a little more
blind spot view... it helps if you put the driver's side Paseo mirror on the passenger side Tercel housing, & vice-verse, because of the shape...
plus they look cool 'cuz the shape is odd in the housing... i'll post a pic in my WIP as soon as i finish my mirror mods...
side note: when working on mirrors of a car that has been sitting for several months,+, tap on the mirror a couple of times to see if wasps are
nesting inside... i learned this the hard way... my ring finger looked like a bratwurst after the sting...
A few years ago, I remember trying to put a Paseo window regulator in my Terc, but I couldn't wind the window all the way down or all the way up, I
don't remember which anymore. I could have installed it wrong, but just wanting to make sure that's verified.
And I have a Paseo trunk release on my Terc, and it seems a little short. It works, but it's a tad short, but maybe the way I have it routed is
wrong...dunno. The fuel door release length is fine though.
actually, your right... my window doesn't roll all the way down, but i'm planning to do more work on the doors when i install stereo, so i'll remove
the Paseo regulator & compare it to the stock Tercel one... then i'll post back if they are different, or if the gears just need skipping...
i'll check my cable routing when i get my new door... i thought it fit fine... but i still need to snap all the fasteners in...
Glad to know that 5th Gen Terc, 1st & 2nd Gen Paseo springs all fit on 4th Gen Tercs.
Has that been verified?
Just wondering as I'm looking to pull the trigger on some Tien Springs for a '95 Terc to install onto my 4th Gen Terc
Paul
'92 Tercel DX | Paseo interior | Miata rims | lowered on KYB + Eibachs
'94 Tercel - base model | Corbeau Seats | Cosmo short shifter | Miata rims
