 Pages:  1    3
Author: Subject: DRL disable
St_Mu69
Mood: Fast and Furious
[*] posted on 28-3-2012 at 08:23 AM
DRL disable
Hi,
here in canada, we have a super day time running light!
Any way to disale this? because i will have HID and DRL will interfer .
thank you
Mu:waving:
--- Full Part catalog---
Kobesama
Mood: swangin'
[*] posted on 28-3-2012 at 01:00 PM
I still have my Daytime running lights and I run 6k HIDs, they don't seem to interfere with anything.
95 Seo
St_Mu69
[*] posted on 28-3-2012 at 01:09 PM
My friend got some in his 5th gen and the blink if light are not ''ON''.
Will see when i will install mine!
thank you !
[*] posted on 28-3-2012 at 01:36 PM
The module in the middle behind the radio, pull the black with yellow strip wire and that disables them, I had the same issue with my install, now it's all good
You don't have to take anything apart, it's easily accessible, it's literally beside your right foot while driving
[Edited on 28-3-2012 by 4agetercel]
Goat
AKA...silent_night88
Mood: chirkin it up
[*] posted on 28-3-2012 at 01:37 PM
Not to thread jack
4age...whats up with the mistress...i mean the supra?
:lachen:
AKA --> Silent_Night88
http://board.tercelonline.com/viewthread.php?tid=42786&page=1#pid47...
"People should not be afraid of their governments; Governments should be afraid of their people"
~EP91 4EFTE~Revva Harness~Tubular Intake Manifold~Custom Ram Intake~FMIC~HKS Style BOV~NRG AFPR~AC/PS ~Delete~NST Pullies~ClutchNet 6 Puck Solid Hub Clutch Disk~ClutchNet Stage 3 Pressure Plate~NGK Plugs and Wires~Speedvision Exhaust Manifold~HKS Adjustable Wastegate Actuator~Emange Blue~Paseo Brake Upgrade~SS Brake ~Lines~SS Clutch Line~Anti Lift Plates~Gutted Cat~Brass Shifter Bushings~Paseo Front Sway Bar~Speedvision Light Weight Cam Gear~
[*] posted on 28-3-2012 at 01:44 PM
Big turbo needs big money lol
Emailed a guy about a transmission but he isn't getting back to me, gunna get squirt(Giggity)v3 to run this thing, just need to find coils that fit it so I can run cops instead of 2 dizzys,
St_Mu69
[*] posted on 28-3-2012 at 01:47 PM
Will do this if any I have any issues with me DRL.
:thanx:Mu
[*] posted on 28-3-2012 at 01:51 PM
You probably will, I just pulled the pin from my connector and left it there in case I need to hook em back up,
St_Mu69
[*] posted on 28-3-2012 at 01:55 PM
good idea! :2thumbsup:
Turd-cel
[*] posted on 7-4-2012 at 12:06 AM
I think it depends on what kind of relay your kit came with. If the trigger voltage on the relay is low enough, then when you turn on the car and the DRL's are triggered, then your HIDS will just come on. That was the case with the 6000k kit I got and it's been working fine for 2+ years.
St_Mu69
[*] posted on 7-4-2012 at 08:27 AM
^^ I have installed my HID and I have no problem with them :)
Maybe just my friend with is 5th gen!!!
Gegueure
Mood: TerSeoless.
[*] posted on 15-8-2012 at 10:01 AM
Thread Revive!
I'd like to either disable DRL on my Paseo or modify it so i can use LEDs as DRLs instead, so am i also looking for a black wire with yellow strip?
If i can't modify it i'd still like to disable them and i'll wire them somehow else and thrust myself not to forget to turn on the LEDs everytime i go...
Why do i want to do this?
-Well i could get a little efficiency from not powering halogens when i totally don't need them.
-Because it just might look cool.
[Truth]
-Because i don't have cable TV and my PS3 died on me and i need to kill time... (Miss Gran Turismo so bad :weeping:)
-because i can...
[/Truth]
1997 Gen2 Paseo 100% stock (So, DIS 5EFE with stock ECU...)
[Edited on 15-8-2012 by Gegueure]
Gegueure
Mood: TerSeoless.
[*] posted on 16-8-2012 at 10:19 AM
:bump: If you don't mind.
St_Mu69
[*] posted on 16-8-2012 at 10:47 AM
DRL with halogen ARE really usefull with winter :)
Halogen will heat and melt the ice ... no heat with LED
:twocents:
Gegueure
Mood: TerSeoless.
[*] posted on 16-8-2012 at 11:12 AM
Interesting point Mu. I'll keep it in mind.
So maybe i should do this the other way around.
Adding a switch to my Low-Beam headlights to cut them off altogether, the wire LEDs independently, also with their own switch...
I'll see if i can do that cleanly...
On the other hand i was planning on getting a winter beater so that the Paseo doesn't have to face snow anymore...
 Pages:  1    3
