Author: Subject: Alternative Oil Filters
SlammedSix
icon_article.gif posted on 16-1-2012 at 06:54 AM
So I pulled my car into my shop to do an oil change and trans fluid change. I drain my oil and am all ready to screw the new filter on the motor and notice that my 2 oil filters I had were for my Toyota Camry instead of my Tercel. So I was kinda like well what the hell. Check the threads and its fits, and checked the seal and its fits flush on block. The filter is almost 2x the size of the Tercel one.
So its not some great upgrade, but you now have the option for a larger freer flowing option if anyone cares.
Apparently Toyota used the part# 4967 for every damn 4-cylinder motor you can think of. My Camry is a 6 cylinder and uses the part# 3614. So do what you will with this. :twocents:
[Edited on 17-1-2012 by SlammedSix]
[*] posted on 16-1-2012 at 06:56 AM
nice:lachen:
[*] posted on 16-1-2012 at 07:46 AM
People already do this...me however i dont...i probably should
TercelTommy
[*] posted on 16-1-2012 at 10:06 AM
That's nice to know!
Thanks, Tom
[*] posted on 16-1-2012 at 02:57 PM
using the 3614 is a gamble due to the gasket being a larger diameter than the 4967
you could get the 4386 which is the same diameter as the 4967..just a lil taller
or you could go for the 2951 - which is the same dimensions as the 3614 but has the same diameter gasket as the 4967
these are FRAM #s btw -
Thread Topped
16-1-2012 at 04:18 PM
SlammedSix
[*] posted on 17-1-2012 at 09:45 AM
I measured the gasket of the 3614, and from off the top of my head the ID was 63mm and OD was 68mm. When measureminf the oil filter flat base on the 5E block I have It was a hair bigger than 70mm. So It definately pushes the limits.
The OEM 4967 gasket was 59mm ID, and 63mm OD
Well I am glad other have tried this and confirmed it. :2thumbsup:
St_Mu69
Mood: Fast and Furious
[*] posted on 17-1-2012 at 10:00 AM
4386: what application? because i wont use fram number since i'm working at Napa DC :)
[Edited on 17-1-2012 by St_Mu69]
--- Full Part catalog---
fowcbler
Mood: Happy to be driving my car again...
[*] posted on 17-1-2012 at 10:07 AM
The 4386 is also a Fram number...just cross reference the filter numbers since you work for NAPA.
St_Mu69
[*] posted on 17-1-2012 at 10:38 AM
PH4386 = NGF 7145 (NAPA number) :thankyou:
here part info:
Part Number: 57145
UPC Number: 765809571457
Principal Application: GM (99-05), Toyota, Lexus (88-12), Scion xB (09-12) Various Ford-New Holland Tractors, Suzuki (96-10), Suzuki Marine Engines, Cub Cadet lawn tactors
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 400
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
My price for this item : 5$ taxes-in :2thumbsup:
[Edited on 18-1-2012 by St_Mu69]
rustyvolvo
[*] posted on 19-1-2012 at 01:09 AM
In the applications list the 2951 is listed for the 3E
TOYOTA Tercel 1987 4-1.5L 1 bbl. 3E
so it should be a proper larger filter, thanks Revva
logtail
[*] posted on 19-1-2012 at 08:00 PM
Wouldn't use a fram if I were you... They've been recalled several times... They come apart...
[*] posted on 19-1-2012 at 10:58 PM
Purolator ftw
NYCtercel
Mood: ZOOM!
[*] posted on 19-1-2012 at 11:02 PM
K&N and Napa for me Also TRD makes the best oil filter for our cars!
[Edited on 20-1-2012 by NYCtercel]
logtail
[*] posted on 20-1-2012 at 01:52 PM
I've actually used k&n quite a bit because oreilley's usually has a deal- k&n oil filter and 5q of royal purple for like $30
[*] posted on 20-1-2012 at 02:23 PM
strangely enough, i only use FRAM:dunno:
