 Pages:  1  2    4
Author: Subject: ACIS Info (good stuff) (Moved over from alf's 'Darth Vader' thread)
[*] posted on 24-7-2011 at 02:14 PM
Quote: Originally posted by Kobesama
The reason the solenoid would not activate was due to the low
amperage output of the MSD rpm switch. These switches are meant
to run shift lights and therefore have a very low output of 1.5 amps.
Therefore a very easy solution was created which incorporated a
30amp relay. The wiring diagram I used for the switch and the relay
can be found HERE <- clicky
Also, during the whole intake rebuild, I purchased the gaskets at
http://www.amayama.com/ for a reasonable price of $35 USD
shipped and took about 3-4 weeks for delivery. I thought this was
pretty good seeing as I ordered the gaskets shortly after the whole
earthquake incident.
Part numbers:
17179-11010 Secondary runners (4 port)
17171-11010 Intake body (8 port)
Would a relay be needed?
[*] posted on 24-7-2011 at 02:16 PM
Quote: Originally posted by ddavis
I think that I finally understand how to make this work but:
"now when the solenoid is opened or closed by the rpm switch
this allows the vacuum stored in the brake booster to act on the
ACIS actuator"
I need to know where to get this solenoid.
Aren't you glad I beat this "dead horse" just one more time?
alf :haha:
[*] posted on 24-7-2011 at 02:55 PM
Quote: Originally posted by sleepyrz
that is a separate air filter so stuffdoesnt get in the lines and stop the
solenoid from opening/closing
its one of these
What are these called and where are they obtained?
alf :dunno:
[*] posted on 24-7-2011 at 02:59 PM
if the rpm switch is low output then, yes, a relay would be necessary.:deal:
btw, if you gotta beat dead horses to get more horses - go for it :lachen:
fowcbler
Mood: Happy to be driving my car again...
[*] posted on 24-7-2011 at 03:26 PM
So a brake booster creates its own vacuum? Hmmm....I need to go to do some reading on how that system operates then.
[*] posted on 24-7-2011 at 03:36 PM
its one of these
alf :dunno:
remove the img code from the pic above and you'll see they are called 'Air-Vacuum-Filter'
the link Doug posted of the vsv shows the 3rd nipple (leg) of the vsv is already equipped with an air filter (the cylindrical looking knob at the end of it).:deal:
[*] posted on 24-7-2011 at 03:40 PM
where did you get that from? it doesnt create vacuum - it stores it (via the one way valve inline) so your brake will still have power assist when vacuum is absent.
ever try to apply the brakes when the booster is bad or when there's no vacuum assist?
[*] posted on 24-7-2011 at 03:51 PM
depends on what you are using to trigger the VSV/solenoid
what will be triggering the solenoid?
haltech-not sure of amperagee output
msd switch-1.5 amps
granatelli switch-2 amps
your best bet is a NOS window rpm switch they can drive solenoids directly up to ~15 amps http://www.holley.com/data/Products/Technical/199R10482rev4.pdf
or find a VSV with low amperage draw under 2 amps and get the granatelli
honestly though
the simplest method ive thought of so far is:
take off diaphragm and all that so all that is left is the arm to move the butterflies
then take it to an airplane/helicopter hobby shop hand it to him and say i need a servo motor twelve volt that will move this arm here back and forth this far
then get rpm switch to activate servo
and done
servo moves arm when rpm is reached
[*] posted on 24-7-2011 at 03:57 PM
i mentioned the servo option off the air
bottom line is though - there are options.
btw, is this a schitcky yet?:dunno:
fowcbler
[*] posted on 24-7-2011 at 04:04 PM
That diagram doesn't show where the booster gets its vacuum from...
Man I am confused. When I get home, ill draw what I'm talking about that's confusing me in paint...
[*] posted on 24-7-2011 at 04:12 PM
jus look under your hood and you'll see where the vacuum comes from - a hose/line from the intake manifold.
im thinking that diagram was drawn with the assumption that one would already know where a brake booster gets vacuum from.:dunno:
fowcbler
[*] posted on 24-7-2011 at 04:13 PM
I like the sound of that servo electronic option tho...
fowcbler
[*] posted on 24-7-2011 at 04:17 PM
That's what is confusing me....I know where it gets it from, but accoding to how it should be set up with that diagram u would split that booster line so it gets its vacuum then it also controls the solenoid.
[*] posted on 24-7-2011 at 04:29 PM
here is a more accurate representation
Resized to 640 by alf
[Edited on 7/24/2011 by alfradio]
[*] posted on 24-7-2011 at 04:31 PM
POIFEC!!!!!
schticky on aisle 'low end tork':lachen:
 Pages:  1  2    4
