 Pages:  1  ..  6    8
Author: Subject: da blue beater
Mood: turning wrenches
[*] posted on 25-3-2013 at 11:13 PM
someone gonna beat me to the 400hp goal daily driver on pump gas?
[*] posted on 23-7-2014 at 05:04 PM
bump its all for sale:icon help::icon help::icon help::icon help::sucks:
[*] posted on 23-7-2014 at 05:25 PM
Quote: Originally posted by sleepyrz
attack package as of yesterday but now with blue NGK plug wires
lengthened intake headers with 55mm 4pin 4age TB
anti-lift/caster kit with poly rear control arm bush
NST pulley set WP ALT CRANK
blue SPEEDVISION all aluminum adj. cam gear
AASCO 5e lightweight fly
ae92/8 trans with quaife LSD diff
blue stainless braided clutch line
clutchnet 4 puck sprung hub notice the springs CAN NOT COME OUT (its like that on both sides)
glowshift wideband
some of the reasons i got it
stuff in da box dark gauge when off
gauge with flash directly on it
aluminum shift cable bushs
the view
also rear sway bar
front swaybar with poly errthang
3 poly motor mounts
ksports
front big brake kit with new rotors and pads
rear disc setup axle
TiAl bov
TiAl wastegate
intercooler and piping
turbo manifold turbo and downpipe
extended intake headers with 4age throttle body(bigger opening) with 4 wire TPS
waterpump pulley
alternator pulley
blue anodized lightweight adjustabe cam gear
aasco ligtweight flywheel with clutch and pressure plate
nice 5 speed trans with quaife ATB dif
braided clutch line
gauges glowshift 7 color series: air fuel ratio, oil pressure, boost
aluminum shift bushings
MSD digital 6 box with 2 step comes with shift knob with switch built in
smoked timing cover
aeromotive FPR
fuel rail wth welded AN fitting for braided line
corsa front grill and headlights
corsa tail lights with wirnig harness
built block forged rods and pistons with all of the bearings installed
there is more im forgettnig
this isnt a i got a baby on the way thread
this is a my life is fucked hardcore and i need money bad thread
[Edited on 7/23/14 by sleepyrz]
[*] posted on 23-7-2014 at 06:23 PM
rear sway bar
3 poly motor mounts both sides and rear
k-sports
TiAl bov
TiAl wastegate
turbo manifold turbo and downpipe with drain and oil pan to match
waterpump pulley with water pump
alternator pulley with matching alternator and bracket
blue anodized lightweight adjustable cam gear
aasco lightweight flywheel with clutch and pressure plate
braided clutch line
smoked timing cover
aeromotive FPR
fuel rail with welded AN fitting for braided line and braided line +440's
2.5 core honda radiatorwith hardlines a 14" pusher fan
corsa front grill and headlights with city lights
built block forged rods and pistons .5mm over with all of the bearings installed by toyota
4e offset filter adapter
sandwich plate for oil sensor and/or larger filter
starlet strutbar
4 point lower control arm brace
firewall to control arm braces
control arms with graphite impregnated poly bushings
gt-revva wire harness
emanage blue
emanage blue harness
emanage blue jumper harness
emanage ultimate
emanage harness
there is still more im forgetting
[*] posted on 23-7-2014 at 08:06 PM
Is the car still together and running?
[*] posted on 23-7-2014 at 08:28 PM
its still together....not running
the forged block was going to go in within the week but life decided to take a shit on my plans
 Pages:  1  ..  6    8
