 Pages:  1  2    4  ..  9
Author: Subject: Rotor For Your Corolla Brake Upgrade
SlammedSix
[*] posted on 5-10-2010 at 04:22 PM
!!UPDATE!!
OK, I got good and bad news
-GOOD-
It all went together great, and I was able to spin everything by hand and it spun freely and seemed like it would work just fine.
-BAD-
The offset of my Miata rims will not allow me to put my rim back on over the corolla caliper.:angry: From the looks of it the Corolla Caliper outer brace sits out farther than my Tercel one. So my only option is either buy new rims or toss a spacer for my rims.
So It works :bananarock: I was just not able to give anyone road test feedback. I am going to be ordering a set of spacers for my rims, so then I can toss all this back on.
eddy_amaya08
Mood: Td04l powered @ 15psi tuned by me
[*] posted on 5-10-2010 at 04:48 PM
This means if I have the corrolla caliper already but I'm using the paseo rotors I can just switch to the Mazda rotors and it should be fine right?
1/8 mile:9.1 @79mph
1/4 mile:13.4 @105mph
can catch me on car domain or myspace: eddy_amaya08
myspace.com/eddy_amaya08
SlammedSix
[*] posted on 5-10-2010 at 05:09 PM
10-4
[Edited on 5-10-2010 by SlammedSix]
[*] posted on 5-10-2010 at 05:37 PM
Bravo SlammedSix, nice find man.:thumbup:
eddy_amaya08
[*] posted on 5-10-2010 at 05:59 PM
Awesome :bowdown:
1/8 mile:9.1 @79mph
SlammedSix
[*] posted on 5-10-2010 at 08:10 PM
I can't wait to feel the difference from my stock Tercel brakes to this upgrade.
Damn Miata Rims:weeping:
icyfyer
Mood: Turbo Withdrawals.
[*] posted on 6-10-2010 at 01:28 AM
So about what size do we need to fit this setup? 15?
This Space for Rent.
riko666
Mood: Lul, whut?
[*] posted on 6-10-2010 at 04:15 AM
What Corolla caliper is this by the way?
SlammedSix
[*] posted on 6-10-2010 at 09:34 AM
They fit under a 14" rim. It would just depend on your offset of your rim, like mine.
I pulled my caliper setup off a corolla from the junkyard. I don't know the exact year but i know its the 93-97 body style.
I also stumbled on a OEM wheel stud that fits our hub and is 7-8mm longer. So I can run my 5mm spacer for my rim:bananarock:
fowcbler
Mood: Happy to be driving my car again...
[*] posted on 6-10-2010 at 12:12 PM
Great info here...I definitely see this as a possible upgrade for several people, including myself.
I did the paseo brake upgrade, and eventhough it was only a slight increase in rotor size, it feels a little more responsive.
juliogonza
Mood: Brazilian wax..... Nice
[*] posted on 6-10-2010 at 12:44 PM
if we can use this we can make a rx7 twin port brake calipers swap like they do in the ae86?
http://www.h5.dion.ne.jp/~messe/u-fc1.html
[Edited on 6-10-2010 by juliogonza]
SlammedSix
[*] posted on 6-10-2010 at 01:14 PM
Well considering the size of the Corolla Caliper and the pad surface. Then toss in a thicker, bigger rotor all on a ~1900lb car :yikes: That is some braking:2thumbsup:
eddy_amaya08
[*] posted on 6-10-2010 at 02:03 PM
Well I can certaintly say that the corolla calipers make a huge diffrence from stock tercel breaks I recomend these over the paseo ones specially now that we have the Mazda rotor to go w it :thumbup:
1/8 mile:9.1 @79mph
SlammedSix
[*] posted on 6-10-2010 at 02:33 PM
Some info on the wheel studs in anyone is interested in a longer stud to feel safer when running spacers.
OEM 91 Toyota Tercel - Dorman #610-244 - 37mm
OEM 95 Toyota Corolla - Dorman #610-266 - 40mm
OEM 07 Toyota 4Runner (Rear)- Dorman #610-462 - 45mm
[Edited on 3-11-2010 by SlammedSix]
SlammedSix
[*] posted on 12-10-2010 at 06:42 AM
I ordered a set of spacers with extended wheel studs for my Tercel. So when I get those I can put my brakes on. I will post pics:thumbup:
 Pages:  1  2    4  ..  9
