stratus19
posted on 28-7-2010 at 04:51 PM |
Has anyone put a hitch on and trailered a small trailer on a 4th gen Tercel?
I dont know if it is smart but has anyone done it? what is the most you have towed? thnks
Mood: RWD here I come!!!
posted on 28-7-2010 at 04:59 PM |
I pull my boat with mine. I've out run a Z71 pickup with the boat on the back too!!
Doesn't go up wet boat ramps very well though.
| Quote: | Originally Posted by BLUEMEANIE
If a member no longer considers themselves a noob, they should work toward becoming a teacher.
stratus19
posted on 28-7-2010 at 05:02 PM |
hah thnks. how much does your boat and trailor weight?
posted on 28-7-2010 at 08:17 PM |
The boat is a 12' fiberglass with 15hp outboard. Total weight on trailer I'd estimate 900lbs. The trick though is I have it balanced so the tongue
weight is only about 75lbs. I've heard to keep tongue weight less than 200lbs. I think 200 would damage the rear struts.
posted on 29-7-2010 at 08:41 AM |
think of a 200 pound dude standing on the back
make it less than that
of course you could always go buy a set of air shocks and weld up a mounting point for it in place of the stock rears or hell maybe they will just
bolt in lol
4EFTE ............................................. HKS IRIDIUM PLUGS (BYP)
GReddy E-MANAGE (BYP).................3\" MANDREL BENT EXHAUST
3\'\' IN/OUT MUFFLER DEEP TONE......GReddy FULL AUTO TIMER
COLORMATCHED BYP HARNESS.......KYB GR2\'s
SARD BOV........................................HI LIFT CAM
TURBO XS 2STAGE BOOST CONTROLLER
FRONT SWAYBAR..............................FRONT STRUTBAR
STAINLESS DECAT D/P.....................CUSTOM INTAKE SETUP
GAUGES(BOOST,TACH).....................STARION FMIC
TRD plug wires.................................2\" drop eibach springs
posted on 29-7-2010 at 08:45 AM |
oh and you never specified what kind of trailer
what the load is
or approximately what it might weigh
Melvin
Mood: collectifyin' parts
posted on 29-7-2010 at 10:04 AM |
wanna say that balance should be key no matter what your pulling.
And i know for a fact that one of those kit trailers from harbor freight tow just fine & I have personally witnessed a 4th gen towing a 4 wheeler
(the kind you take to the hunting lease, not the dirt pit racing kind) i wouldn't try to pull a pop up camper though.
but it would help to know what you're trying to achieve in the end...
stratus19
posted on 29-7-2010 at 07:07 PM |
The most i would tow is like an old coleman pop up but it would probably just b a small single axle trailer to tow say a dirt bike or an atv. nuthin
over 1000
posted on 29-7-2010 at 08:49 PM |
as long as you can get the weight of that bad boy nice and even on the axle of the trailer to keep a low tongue weight
i would get the paseo brake upgrade for sure tho
Melvin
posted on 30-7-2010 at 03:38 AM |
something to think about with the whole pop up trailer bit.
would it be just you or you and another person? or you and some people?
lets say its just you maybe one extra person. build a minicamper using a kit trailer as a base. or set up the kit trailer so you can set up a tent on
it. here is a rough idea of what i mean
http://dornob.com/modified-bike-trailer-doubles-as-diy-mobile-camper-home/
something like this would put the least amount of stress on your car, and if you do it right can actually be pretty comfortable (and cheap)
if the idea is to pile 3-5 people in the car plus all their crap and tow a coleman pop up, buy a beater truck. save yourself some pain
[Edited on 30-7-2010 by Melvin]
posted on 30-7-2010 at 07:30 AM |
Funny thought, I've seen Tercels being pulled behind campers for a kicker car but this will be the first time I saw a Tercel pulling a camper.
ddavis
Member Is Online
Mood: Blessed
posted on 30-7-2010 at 10:15 PM |
Front wheel drive cars are not really suitable for pulling a trailer. Remember, the Tercel is about the lightest car out there. Pulling the weight
is half the problem, the other is stopping. I would think that the very most you should consider is a flat bed aluminum boat with your 15 inside.
posted on 30-7-2010 at 11:36 PM |
Actually other than leaving a stop you wouldn't know it's back there. I do have overkill rear brakes though.
