Author: Subject: Turbo timer plug-n-play harness definite answer needed
[*] posted on 19-12-2009 at 04:13 PM
I looked around the board and saw 2 answers:
- SW22 turbo timer harness
- JZA80 turbo timer harness
Which one is it exactly?
I'm looking at a HKS turbo timer btw
[*] posted on 20-12-2009 at 07:47 PM
I wasn't sure either, so I just wire it straight in to the ignition/key cylinder harness.
airswoosh1
Mood: 4EFTE Corsa
[*] posted on 20-12-2009 at 08:42 PM
Originally posted by galitxxo
for the long wait. i purchased the harness about a week and half ago and i just barely received today.-irked- its a greddy turbo timer harness. by the looks of it, it looks like it might work. on the back of the box, it has the part number of the harness for specific applications. according to the table by greddy:
------------| TT14-14 | --------------
..................2JZ-GTE
..................1JZ-GTE
..................2TZ-FE
..................5E-FTE
..................4E-FTE
..................3C-T
..................2L-TE
..................1N-T
TT14-14 is the harness i purchased so it should work. i will test and compare with the harness i have inside my car tommorow morning. if anything, this harness will ony work for greddy turbo timers since i have an hks but....ill let you know-coolguy-
btw i'll try to get a pic of the back of the box, it has all engine codes with what harness part number.
rz
*update* harness works perfectly!! even with my old school hks timer. so anyone looking for a custom wiring for your harness, f.uck that zhit. all you have to do is buy one off a 93+ supra TT and your good to go!-deal-
[Edited on 6-3-2006 by galitxxo]
from this thread: http://board.tercelonline.com/viewthread.php?tid=24594
[*] posted on 20-12-2009 at 09:00 PM
I also came across the above quoted info. I'm guessing if the harness is for any of the applications in quote, harness brand doesn't matter, right?
airswoosh1
Mood: 4EFTE Corsa
[*] posted on 21-12-2009 at 06:43 PM
That's what I'd assume. He used it for an HKS even though it was a Greddy harness.
Matt87
Mood: Loving the GT2560R Life!!
[*] posted on 21-12-2009 at 11:41 PM
Just buy one for an ep82 it plug and play no problems.
First Tercel on E-85/ self tuned!
[*] posted on 23-12-2009 at 10:14 AM
Did a bit of digging based on the above info and the assumption that the wiring on 91-94s Tercs, EP82s and 95-99s Tercs, EP91s may differ; I came up with this:
-HKS turbo timer harness TT4: 93-96 JZA80, EP82 (91-94 Tercs)
-HKS turbo timer harness TT7: 97-98 JZA80, EP91 (95-99 Tercs)
Matt87
[*] posted on 23-12-2009 at 09:14 PM
I bought mine for the same year as my tercel. Plugged it in and it works perfectly.
