Author: Subject: interchangeable injector list
ruggiero06
Mood: Paint and paste removal....fml
icon_article.gif posted on 8-11-2009 at 02:14 PM
Heres a list put together with the research i did on http://www.miataturbo.wikidot.com, http://www.witchhunter.com, http://www.rx7club.com, http://www.honda-tech.com, http://www.tercelreference.com, and the best for last TERCELONLINE.com.
High Impedance - No resistor box required:rockon:
Toyota MR2 4AGE 213cc – Beige Top #23250-16080
B2220 Truck 224cc - Yellow Top #23250-74040
Toyota 4AGE 250cc – Green Top
Toyota 4AGE 250cc – Violet Top
Mazda Miata 254cc - Tan Top #195500-2180
Mazda Miata 260cc - Thin Red Body #195500-3310
Mazda Miata NA & TURBO 265cc - Thin Lt. Purple #195500-4060
Toyota 3SGE 295cc – Green Top
Toyota Supra (7MGE) NA 295cc – Yellow Top #23250-70040
Toyota Supra 7MGE 315cc – Light Green Top #23250-70080
Toyota Supra 312cc - Maroon Top #23250-46030
Toyota 3SGE 315cc – Pink Top
MX6/626/Probe Turbo 326cc - Gray Top #195500-2150
B2600 Truck 326cc - Gray Top #195500-2150
Mazda 323 GTX Turbo 360cc - Black Top #195500-2130
Celica/MR2 3SGE NA 370cc - Green Top #23250-74160
Mazda RX7 420cc - Yellow Body #195500-4450
Mazda RX-7 NA 440cc - Blue Top #195500-5740
RX-7 NA 460cc - Red Top #195500-2010
RX-7 Turbo 550cc - purple top #195500-2020
Low Impedance - Resistor Box Required
Toyota 4AGZE 365cc – Red-Orange Top
Toyota Supra 7MGTE 440cc – Black Top
Resistor box information
Dzaster made a good DIY write up
http://board.tercelonline.com/viewthread.php?tid=41009
good discussion about the above thread.
http://board.tercelonline.com/viewthread.php?tid=39809
good DIY and write up
http://www.honda-tech.com/showthread.php?t=517274
also the clips may be different requiring you to cut and solder in the different clip. not a big deal.
any additions, comments, errors, changes are welcome
[Edited on 11-13-2009 by ruggiero06]
My 3sgte rebuild and swap:
Part 1 Part 2
riko666
Mood: Lul, whut?
[*] posted on 8-11-2009 at 02:44 PM
7MGE Supra is 315cc/min
riko666
Mood: Lul, whut?
[*] posted on 8-11-2009 at 03:21 PM
no problem :2thumbsup:
[*] posted on 8-11-2009 at 04:06 PM
and side feed and top feed injectors are NOT interchangeable.
there was never a Corolla GTS turbo...ANY year.
no all motor 3SGE ever came with 370s...
89-92 7MGE came with both high and low impedance? NO
88-91 RX8??
not an accurate list at all.
ruggiero06
[*] posted on 8-11-2009 at 04:15 PM
88-91 RX8??
http://miataturbo.wikidot.com/fuel-injectors
miata injectors fit in our car. i searched cars that were proven interchangeable with our cars and found this list.
i will make fixes.
and obviously 88-91 was meant to say rx7.
problem is there was a site that had all the toyota injectors and i cant seem to find it so im trying to make a master list with the help of everyone. the more input we get the better the list can be. this will only help everyone save money on injectors as those are pieces that are swapped out quite frequently.
[Edited on 11-8-2009 by ruggiero06]
Part 1 Part 2
ruggiero06
[*] posted on 8-11-2009 at 04:27 PM
changes made. remember this list was made by a miata driver so the assumed the 4agze motor was turbo when it was actually sc'd.
i thought these were all top feed. which ones are side feed so they can be removed?
Part 1 Part 2
[*] posted on 8-11-2009 at 05:13 PM
This might help you a bit -> http://www.tercelreference.com/tercel_info/injectors/injectors.html
:waving:
ruggiero06
[*] posted on 8-11-2009 at 06:15 PM
:waving:
yes that what i was looking for...now i can add/remove more stuff yay
Part 1 Part 2
[*] posted on 9-11-2009 at 12:09 AM
Thing is TercelReference is, in a sense, TercelOnline's database for specs and details on our cars and parts, that's why no one really tried to migrate a list over. It's been there a while and has been serving the community just fine.:dunno:
[Edited on 11-9-2009 by Dzaster]
ruggiero06
[*] posted on 9-11-2009 at 01:48 AM
Originally posted by Dzaster
Thing is TercelReference, is TercelOnline's database for specs and details on our cars and parts, that's why no one really tried to migrate a list over. It's been there a while and has been serving the community fine.:dunno:
thats true but that list is smaller than this on and only lists toyota injectors.
is a more in depth and more diverse list a bad thing?
Part 1 Part 2
chucky
Mood: C-P&a performance
[*] posted on 9-11-2009 at 12:53 PM
yeah.... i had a 91 maSda ex8...lol
[*] posted on 11-6-2011 at 12:11 AM
buuuuuuuuuuuuuuuuuuuuuuuuuuump
t_cel_t
Mood: Im a working fool
[*] posted on 11-6-2011 at 08:16 AM
i can tell you for sure that subaru blue/sea foam injectors fit in a 5efe rail perfectly with the black plastic spacers removed form the rail bolts.
and the clips are exactly the same as a 5efe, 2 are the same on a 3ee.
Fuelly
[*] posted on 11-6-2011 at 10:33 AM
which would be what size?
t_cel_t
[*] posted on 11-6-2011 at 06:11 PM
blue subaru -440cc, 850cc uncapped
next to a supra 440
and its high ohm
Fuelly
