 Pages:  1  2    4
Author: Subject: My Project... 95 tercel. Update 02/22/16
5efhe-Tercel
Mood: N HIM...
[*] posted on 27-9-2009 at 10:27 PM
What lowering springs are you now using? :dunno:
Ken
For now...2004 Acura RSX type S...
[*] posted on 27-9-2009 at 10:28 PM
Ken
TEIN
Lowered like 1.5 inches... rides really good...:thumbup:
poordude2151
Mood: Sometimes Pain blinds us of our happiness. Stay strong, and happiness will follow!!
[*] posted on 27-9-2009 at 10:47 PM
Originally posted by kennymp3
Here is the the TPS on ebay for around $60 bucks...
http://cgi.ebay.com/Toyota-Starlet-Turbo-EP82-Throttle-Position-Sen...
and here is the ignitor......(kinda spendy)
http://cgi.ebay.com/ebaymotors/Toyota-EP91-Turbo-Starlet-Igniter-4F...
Hope this helps:dunno:
I would just get the TPS from Toyota brand new and you know it will work. Cost the same!
You can get an igniter from another car, look at my 4e parts list.
The igniter is a $200 part from the auto parts store so J/Y would be best.
[*] posted on 27-9-2009 at 11:24 PM
Here is billys 4e parts list......:2thumbsup:
http://board.tercelonline.com/viewthread.php?tid=38743
[Edited on 9-28-2009 by kennymp3]
95greeneturtle
Mood: Boostin NEPA
[*] posted on 27-9-2009 at 11:37 PM
about time this thing got a 4e!! lol i can prolly hook you up with some pedals and misc. electronics if your interested shoot me a u2u
5efhe-Tercel
Mood: N HIM...
[*] posted on 28-9-2009 at 12:51 AM
I have Tein also but my cars rear sits much higher! :dunno:
Ken
poordude2151
[*] posted on 28-9-2009 at 08:33 AM
Thanks man, you the man!
[*] posted on 30-9-2009 at 09:24 PM
so i got the engine but there are some problems...
How come only 1 plug fits?? this is suppocely a byp harness....
what are these plugs for??
this thing is broken... whats it for?
anyone know what these wires are for?
anyone know what this blue wire is for?? it runs to a green wire on the harness close to the ecu plug and it comes all the way to the positive cable
cannot find the connector to this temp sensor
poordude2151
[*] posted on 30-9-2009 at 11:29 PM
I am going off my experience with a 3ee/4e harness so bare with me
2nd pic- you are missing a plug there should be another grey one.. The blue and white plug goes to the dash or body harness...
3rd pic- the big plug looks to be the wiper motor plug and the other looks to be the coil plug- (not 100% sure on that.)
4th pic- not sure what its for but I believe you can use yours off the 5efe..
6th pic- looks like some one rigged something... I would trace that green wire that the blue wire is on back to the ECU and let me know what pin and I can tell you what the green wire is for.
7th pic- I don't have this hooked up and BYP never installed a plug so I assume not needed.
poordude2151
[*] posted on 30-9-2009 at 11:34 PM
You also stated in another htread you need a stock BOV? Well that one looks fine it just is off the filter tube that goes to the turbo. It was on the filter tube because it was getting vented into the filter then out to the world haha. I had mine like that till I upgraded..
[*] posted on 30-9-2009 at 11:35 PM
theres a plug there but it has like a jumper block... and if you take the jumper block off, it doesnt fit the ecu... it looks to be a 5e plug
poordude2151
[*] posted on 30-9-2009 at 11:43 PM
I see the black one... That shouldn't be it at all since that is way to short... It should be the same length as the 26pin plug.. The plug you need is a 16 pin plug...
Here are the pins in each
4E-FTE EP82 ECU 89661-10040 GREEN STICKER ma-5450
26 pin plug
1 ~ ~
2 NSW Neutral Starter Switch
3 THW Water Temparature Signal
4 PIM Pressure Intake Manifold
5 THA Intake Air Temparature
6 IGT Ignition Timing
7 IGF Ignition Feedback from the Ignitor-Coil
8 G1 Distributor
9 G- Distributor Crank Angle
10 OX Oxygen Sensor (Lambda Sensor)
11 STA Engine Cranking Signal (Starter Switch)
12 #10 Injector Pulse 1 & 3
13 E01 Computer Ground
14 DISC Aux. Control Valve or Idle-Up System Vacuum Switching Valve
15 VSV1 Air Control Vacuum Switching Valve
16 E2 Sensor Ground
17 PSW Throttle Position Sensor
18 VC
19 IDL Throttle Position Sensor (Signals ECU throttle position is at idle)
20 G2 Distributor
21 NE Part of the IIA (Intergrated Ignition Assembly) (RPM)
22 E21 Sensor Ground
23 KNK Knock Sensor
24 E1 Computer Ground
25 #20 Injector Pulse 2 & 4
26 E02 Computer Ground
16 pin plug
1 +B1 Switched Battery Power (12V)
2 BATT Switched Battery Power (+12V) (EFI Main Relay)
3 CCO Check Connector Outputs
4 FC Circuit Opening Relay (Fuel Cut)
5 ELS Electrical Load Signal System Taillight Relay
6 AC2 12V To Aircon Computer
7 BC Boost Control
8 T
9 +B Switched Battery Power (12V)
10 W Warning Light
11 EGW Catalytic Converter Temparature Warning Light (Combination Meter)
12 ~ ~
13 SPD Speed Signal
14 ACT A/C Cut Control System
15 AC1 A/C Switch Signal System (12V to Aircon Computer)
16 VF Check Connector Outputs
[*] posted on 30-9-2009 at 11:45 PM
Just though of something... that plug can be inside the car.. on the cars harness...
poordude2151
[*] posted on 30-9-2009 at 11:46 PM
now if you have this ecu then this is the pinouts in each
4E-FTE EP82 ECU 89661-10100 GREEN STICKER ma-5970
26 pin plug
1 IPV Vacuum Switching Valve
8 G1 Distributor
16 E2 Sensor Ground
18 VC
20 G2 Distributor
23 KNK Knock Sensor
16 pin plug
7 TE2 Check Connector
8 TE1 Check Connector
10 W Warning Light
12 AC1 A/C Switch Signal System (12V to Aircon Computer)
13 SPD Speed Signal
15 BC Boost Control
poordude2151
[*] posted on 30-9-2009 at 11:48 PM
I believe it should be on the harness since the last time I looked (6 months ago) there were 2 ecu plugs on the engine harness... I could be wrong though.
 Pages:  1  2    4
