Author: Subject: Myth Dispelled: Comparison between EP91 and EP82 Axles
[*] posted on 19-5-2009 at 08:49 AM
Let's spark some interest first to find out
[*] posted on 19-5-2009 at 10:18 AM
i'm in
geocool69
Mood: SuperStyling!
[*] posted on 4-6-2009 at 07:29 PM
very interesting riko, does that mean the track of the ep91 is ten mil wider at the back?
would you mind pasting your findings into a tutorial page in the suspension section of the wiki of my site??
トヨタ スターレット
http://www.ukstarletclub.com - extreem ep
do you like my site?
riko666
Mood: Lul, whut?
[*] posted on 4-6-2009 at 08:34 PM
It would depend on the offset of the wheels, I believe they changed a bit didn't they from GT to Glanza? And feel free to use it chap, or I can post it, whatever suits you best
[*] posted on 15-6-2009 at 06:19 PM
I know this is a little outside the subect title, but I had to grind down this part on my 93 Tercel axle to gain clearence for the caliper to move freely--or to even bolt up for that matter.
There must be some differnces in tercel axles as I seem to be the first on here to be reporting this problem.
[*] posted on 15-6-2009 at 08:22 PM
Originally posted by madRPM
Interesting! Don't throw that EP82 rear axle in the garbage yet. I'll get it from you later
I have an EP82 axle and may be going to the meet in July in Orlando......
Just the axle, no other parts.
[*] posted on 15-6-2009 at 08:39 PM
I'm going to look into that as I've not seen this problem before. Let you know what I find soon, I have a lot of extra parts around to look at.
Looked into it, seems the thicker mounting pads create the issue. Is that banjo fitting supposed to be there? Seems like mine had a short metal line kinda like the drums use. For some reason this is really bothering me.
[Edited on 16-6-2009 by Tercel GTS]
[*] posted on 15-6-2009 at 09:00 PM
Yeah, was talking with Riko and just not sure. However, are all rear disk setups ABS? This one came off ABS setup.
[*] posted on 15-6-2009 at 09:45 PM
No, not all are abs. The one I have is ABS but prior ones I've had were not.
