Author: Subject: Myth Dispelled: Comparison between EP91 and EP82 Axles
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 04:08 PM
Right, you may or may not have heard that there was a disparity between the axles from an EP82 and EP91 Starlet turbo, mainly being in the length of the axle, and seeing as I had both laying around, I decided to look into it a bit more.
And right off the bat, the rumours are wrong - it's the EP91 axle that is indeed longer, not the EP82 axle. I'll let the pictures (and subsequent subtitles tell the story):
The difference between the axles
I initially thought the stubs looked different
But evidence of where the difference in length comes from
Further evidence
And another observation
So yeah, mystery dispelled - it is infact the EP91 Glanza axle that is longer than the EP82 Starlet GT axle, by about 10mm - I would think the EP91 Glanza axle is also heavier by a smidge as the hub is elongated in order for a hole to be drilled to locate the ABS Sensor.
[Edited on 19-5-2009 by riko666]
[*] posted on 18-5-2009 at 04:10 PM
:sucks: without a STICKY!!!!
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 04:38 PM
teehee, thanks Trev - when I saw the thickness difference in the hub plates, it was like "..............................*DING*!"
[*] posted on 18-5-2009 at 06:01 PM
The Tercel is like the EP91.
[*] posted on 18-5-2009 at 06:20 PM
Do they share the same bushing though?
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 06:41 PM
Hmmm, well the TRD Catalogue lists different part numbers for them, but, I was using an EP82 Cusco bush on a Glanza axle, it fits, but it gets loose, like, a couple of mm of slack
[*] posted on 18-5-2009 at 06:46 PM
Interesting! Don't throw that EP82 rear axle in the garbage yet. I'll get it from you later
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 06:49 PM
The axle?!! Err, that's going to be killer postage man :dunce: And I was thinking of using it too (well, THAT one at least, the EP82 axle on my car will be for sale...) as I can refurbish it before swapping it with the EP82 axle currently on my car
[*] posted on 18-5-2009 at 07:15 PM
Alright, no biggie then
[*] posted on 18-5-2009 at 07:40 PM
i just wanna know what are my rear bushing options
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 07:50 PM
TRD do them for both axles
TRD for EP82/91 and Cusco for EP82
riko666
Mood: Lul, whut?
[*] posted on 18-5-2009 at 07:57 PM
yup ^^
A polyurethane bush was supposed to be released by a certain trader but his company seems to have dissolved. Alternatively, once I get the Starlet axle on my car, I'll remove its bushes and fill them with 3M, or leave that job to someone else
[*] posted on 18-5-2009 at 08:08 PM
thanks
riko666
Mood: Lul, whut?
[*] posted on 19-5-2009 at 07:22 AM
Could get a group buy going if there's the interest? I'd know who to talk to and they make PU bushes for like, nearly every car in the world...even the London Taxi's!
