 Pages:  1  ..  6    8
Author: Subject: tercel rear disk brake swap
Unregistered
Posts: N/A
[*] posted on 13-9-2009 at 10:51 PM
I have been working on an adapter plate that will accept the corolla front brakes along with the ford escort rear disc/parking brake calipers. The only hold up is you will need access to at least 180 amp welder to weld on the adapter. Oh yeah and the rear suspension sucks completely anyway. No caster, camber or toe adjustments.
[*] posted on 14-9-2009 at 03:05 AM
Why use an adapter when all you need is the corolla bracket calipers rotors and a 3mm spacer.
You should look deep into the other threads before posting a bunch of stuff that has already been talked about.
Search button is a great feature that we have.
[Edited on 14-9-2009 by 4speedsleeper]
drift_ae86_91
Mood: Come soon Spring!
[*] posted on 13-11-2009 at 07:25 PM
I wouldn't worry about the caliper brackets made of aluminum, guy i know well does lots of work for Subaru Rally Canada and he makes aluminum caliper brackets (STi brembo conversion applicable) on his cnc machines, i'd trust what ever grade he uses.
cdnred99
[*] posted on 14-11-2009 at 02:33 PM
we have about 20,000km's on these now with no glitches so I'm no longer worried about the brackets giving us a problem.winters almost here so we'll get to see how they handle snow and ice.
are you sure you won't change you mind? why...is there something wrong with the one i have?
TRD98LE
Mood: None Yet
[*] posted on 9-1-2012 at 07:50 PM
Is there a parts list with numbers , year, make and model? Where to buy these parts if you can't really make them yourself? So far the rotors from a Volkswagen Golf and custom torque brackets? But I always thought that we can bolt on some other Toyota REAR disc brakes and adapt them to the Tercel?
chinesemafia
[*] posted on 15-10-2014 at 10:36 PM
does any one have any update on this
has any one else tried it or found something else which works ?
[*] posted on 16-10-2014 at 08:40 AM
There was another member on here that used the rear disc brake setup from a 1991 Corolla GTS but he is not talking or sharing how it was done
ALL Boost
[*] posted on 18-2-2015 at 06:50 PM
Great work!!!!
digum71
[*] posted on 30-8-2015 at 02:56 AM
I did this setup worked perfect until last friday night when I blew my head gaskit
https://www.youtube.com/watch?v=7BSn177igfM&feature=related
[*] posted on 30-8-2015 at 11:24 AM
[url]https://www.youtube.com/watch?v=7BSn177igfM&feature=related
[/url]
Great job on the swap! You should start a build thread. :deal:
 Pages:  1  ..  6    8
