Author: Subject: Paseo Sway Bar: Energy Suspension Harware Part #'s
Turd-cel
[*] posted on 6-9-2011 at 07:36 PM
If you have a Whiteline swaybar, you may find that the endlinks are quite short haha. I think the Whiteline end flanges are a bit thicker than stock and I had to use c-clamps combined with a kung-fu grip to get these endlinks installed. Once installed and the bushings compressed, there were about 2-3 threads sticking out past the nut.
[*] posted on 6-9-2011 at 07:38 PM
Wow ok.
randomtask16
[*] posted on 7-3-2013 at 09:44 AM
Bummmmp
After finding this thread I ordered and installed the Energy Suspension links/bushings with the stock Paseo sway bar. They do make a noticeable difference in stiffness over the 20yr old rubber parts. Also noticed the links were slightly longer and had a bigger gap down the center than stock. This required putting the car on jackstands, then compressing the suspension with jacks at he same time to they them to line up.
[*] posted on 3-4-2013 at 01:30 PM
Gonna be buying soon. I did notice on the Energy Suspension website that you can order universal motor mount inserts. Anybody happen to know the part number that would work on a 5e?
I want to start replacing all my bushings out.
