Author: Subject: speed limiter mod
[*] posted on 29-1-2009 at 01:57 PM
speed limiter mod
Bringing back a bit of lost information any other lost info can go in this thread as well.:thankyou:
kene
posted on 16-11-2004 at 05:31 AM
Subject: Re: this speed sensor..
To: kene
Sent: 10-8-2002 at 08:32 PM
Message: quote:
can u explain in detail where its at and how to get around it in order to defeat the gov.?
16 pin plug in the back of the ECU....bottom row...4th pin from the left.....cut the wire! Not responsible if you do it incorrectly!
Reply - Forward
[Edited on 5-9-2009 by 4speedsleeper]
[Edited on 11-10-2009 by 4speedsleeper]
[*] posted on 8-8-2009 at 06:36 AM
I don't know this prolly should have been stickied years ago.
http://board.tercelonline.com/viewthread.php?tid=14908#pid126541
[Edited on 8-8-2009 by 4speedsleeper]
[*] posted on 8-8-2009 at 09:53 AM
kene
To: kene
Message: quote:
Reply - Forward
The wire should be yellow. Here's a couple of options to add, 1, make sure the cut is in a place where it cn be reassembled if needed.
2, the cut can be made a lot closer to the instrument cluster as this wire comes directly from the speedometer.
3, instead of a plain cut you can install a switch so the CEL doesn't irritate you everytime you pass about 50mph and light up.
[*] posted on 5-9-2009 at 04:34 AM
Have you done this mod TercelGTS?
t_cel_t
Mood: Im a working fool
[*] posted on 5-9-2009 at 04:58 AM
why cut it when you can just pull the pin, then if you need to you can just push it right back in.
Fuelly
[*] posted on 5-9-2009 at 05:37 AM
Thought about that but how do you pull those pins out?
[*] posted on 5-9-2009 at 09:24 AM
Yes, my wire is cut. I did not install a switch however there's no fuel vcut on the other side of 110mph now.
[*] posted on 5-9-2009 at 12:39 PM
on the side you pop up a pice on the plug, then where the wire is you need a really small flat screwdriver to pull up the tab in the plug and pull the wire out
[*] posted on 5-9-2009 at 02:12 PM
Ok cool I will need to remember that 4agetercel thanks.
rgm1800
[*] posted on 20-11-2009 at 01:20 AM
for what engine is this?
[*] posted on 20-11-2009 at 01:30 AM
Pretty much all Tercel/Paseo/Starlet.
rgm1800
[*] posted on 20-11-2009 at 08:45 AM
have you tried this mod? the problem is the ecl light comes on everytime with these mod.
[*] posted on 20-11-2009 at 06:07 PM
Not every time, but pretty much every time you hit 60mph or so. It was much better to have a light on that I knew why it was on than a car that was limited to third gear.:deal:
Yes I did mine. I cut the wire about 3" away from the ecu.
[*] posted on 20-11-2009 at 06:31 PM
:iwdumbass:
sometimes in the middle of a race i'd count down to the CEL...3,2,1...shift :lachen: should the race have to go over 115 mph :smug:, i wouldn't have to worry about somebody throwing a parachute out my window though...:doh: (that's what it feels like when you hit the speed limiter with a decent amount of power under foot). :deal:
the seat belt will have you lookin like this guy>>:blah:
[*] posted on 2-12-2009 at 11:29 PM
this work for the 3ee ecu? is it the same wire you have to cut on the 3ee ecu ?
