Author: Subject: DIY: Paseo Cluster to 1995+ Tercel! Now with connector(s) disassembly video ** DONE **
what026
[*] posted on 18-3-2012 at 09:17 PM
ok i'll try it like that, thanks for the quick response. What are the connector clips called that you solder to the wires?
what026
[*] posted on 18-3-2012 at 09:41 PM
:icon help: I just notice from the way your holding the connector on my car for the temperature guage on connector A slot 2 and 8 there is already a wire there but on the other side theres no wires??
what026
[*] posted on 18-3-2012 at 10:17 PM
:pepper: Well I just installed it like that plug and play, I did the wires but notice on the connectors they ready had the cables so I just put it on and everything works. Awesome the temp guage, fuel guage , rpm guage work, with no moving wires. I took the paseo cluster off a 1996 toytota paseo today at the junkyard paid 22 dollars for it with the hood opener awesome deal, Note my tercel is a 1996.
[*] posted on 19-3-2012 at 04:27 AM
Yup! As mentioned, I'd heard of this being done with no wires
having to be moved... You are one of the lucky ones!!!
Now go enjoy your new addition...
alf :thumbup:
PS: $22 is a STEAL!!!! :thumbup:
Tercelovod
[*] posted on 19-12-2013 at 07:51 PM
People! Help me! I am russian, and very bad know english.
I have tercel, made in japan. Ignition system Dis2. How install tahometr about tercel ignition system Dis1 (distributor ). Thanks
[*] posted on 7-5-2015 at 09:25 AM
alright, seems like my 96 tercel got every wire already included, awesome!!!
now, how do i remove the speedometer needle?( on the paseo cluster)
[Edited on 7-5-2015 by mycars12]
[*] posted on 7-5-2015 at 03:15 PM
awesome!!!
Carefully....? :dunno: Why do you need to do THAT?
alf :waving:
[*] posted on 7-5-2015 at 09:25 PM
the dreaded mileage change lol, i tried to change the mileage back since my original cluster has 183364 miles and the paseo one got 200835, i tried to figure out a way to change it back but in the end just gave up and wrote down the old mileage and the new one
FoolishSamurai
[*] posted on 19-2-2018 at 11:55 AM
I did this swap yesterday on my 1997
Tercel. I took a black/blue wire from the 1997 Paseo donor car. I traced it across the car under the dash and found it was spliced into the black/blue that runs through the firewall and runs up to the computer behind the glove box. This is how the Toyota engineers did it and you don't have to run a wire through the firewall. It comes through in a white connector next to a blue one.
[*] posted on 28-3-2018 at 10:17 PM
Makes sense, I tapped mine directly into the igniter but going to the ECM makes more sense.
For the guys wanting to correct mileage, if you're patient, you can open the speedo and set it to whatever you want. I usually set them to zero, so I know my mileage is my old cluster + the new one, and I get to goof around with people and say my car has 7000 miles on it now or whatever lol
Also, I put LED backlight bulbs in there, and converted the small T5 bulb to a full size 194 to make it look even. Came out awesome with the white face Paseo cluster. Looks super modern.
