Author: Subject: TERCEL1: Weights 'n' Measures
[*] posted on 17-12-2007 at 12:36 PM
05-21-2007: Okay... I just got back from getting TERCEL1
weighed (on the 4 cornered scales) ...and here are the results:
The car was, put on the scales as it is when it rolls up to the
starting line, ready to make a 1/4 mile run, with a 1/4 TANK gas,
lightweight battery, no rear seat or passanger seat, drag
radials on (15 psi.) rear tires (40 psi) and a very EMPTY trunk!
Keep in mind, during the installation of the 4EFTE motor into
TERCEL1, several things were changed which would give
my car a bit different weight then a similar '89 Tercel.
For example, the car rolled onto the scales MINUS all it's air
condition pumps, condensers, & plumbing. TERCEL1 never
had power steering so that'd be taken into consideration as
well as the fact that strapped to the motor is a lightweight
flywheel.
At weigh-in today, TERCEL1 sported ONLY the driver's
seat while the drag radials was wrapped around 9.18 lbs
14" KOSEI K1-TS wheels. A 15.78 lbs Odyssey PC680MJT
battery provides the juice.
...and now the envelope please...
1812 lbs (without me) and 2037 lbs (with driver)
Here's a breakdown of weight/distribution:
LF = 576 lbs -- RF = 613 lbs = 1189(F) = 65.2%
LR = 344 lbs -- RR = 290 lbs =. 634(R) = 34.8%
* * * * * Weights & Measures * * * * *
For TERCEL4 Weights 'n' Measures, click HERE!
1989 Tercel with a 1.3L 4EFTE
36.20 lbs = Battery (Gold Duralast)
31.34 lbs = Driver's seat
31.34 lbs = Passenger seat
23.96 lbs = Spare tire (14" donut)
22.00 lbs = Rear bumper (partial rebar+)
21.22 lbs = Hunsaker seat/bracket/cushion
20.42 lbs = Diff between regular battery and the PC680
18.98 lbs = 205/55/14" NITTO 555R DRAG radial
16.52 lbs = Back seatback
16.12 lbs = Both GLASS side windows
15.78 lbs = Battery (Hawker PC680)
13.54 lbs = Flywheel (stock)
13.50 lbs = Sound deadening tar
12.80 lbs = Sunroof (ALL)
12.78 lbs = Floor mats (and rubber mats)
12.00 lbs = Front bumper (partial rebar+)
11.30 lbs = Hunsaker baja seat
10.96 lbs = Backseat (bench)
10.78 lbs = Both door panels
10.24 lbs = Flywheel (Lightweight)
10.12 lbs = Diff between driver & Hunsaker seat
09.76 lbs = Diff between glass side windows & Lexan
09.18 lbs = KOSEI K1-TS Aluminum wheel (14")
08.80 lbs = Diff between TWO 195/65 & 175/65 tires
07.50 lbs = Carpeting
07.04 lbs = Both GLASS rear 1/4 windows
06.50 lbs = TRUNK JUNK
06.36 lbs = Both LEXAN side windows
05.94 lbs = Radio/Antenna/Ashtray and stuff
05.54 lbs = Driver seat lumbar support
05.38 lbs = Both window regulators + hardware
05.02 lbs = Backseat belts & hardware
04.28 lbs = Spare wheel cover (fiberboard)
04.06 lbs = SUB Diff between BOTH rear 1/4 windows (glass/Lexan)
03.72 lbs = Both doors (Excess metal)
03.30 lbs = Diff between stock & lightweight flywheel
02.98 lbs = Both LEXAN rear 1/4 windows
02.94 lbs = Hood "X" members + poly adhesive balls
02.86 lbs = EP82/91 Strut Bar
02.50 lbs = Outside mirrors (Both)
02.30 lbs = Front passenger seatbelt
02.10 lbs = 16 Acorn lugnuts (12x1.5)
02.00 lbs = Trunk lid reinforcement
01.48 lbs = 16 KOSEI lugnuts (12x1.5)
00.80 lbs = 16 Aluminum lugnuts (12x1.5)
00.68 lbs = Diff between 16 KOSEI & aluminum lugnuts
SUB = Minus these items, the car/driver weighs: 2037 lbs.
06.50 lbs = Gallon of gasoline
With an 11.9 gallon gas tank, Tercels weighs this much more:
77.35 lbs = 4/4 tank (11.90 gals)
57.98 lbs = 3/4 tank (08.92 gals)
38.67 lbs = 2/4 tank (05.95 gals)
19.30 lbs = 1/4 tank (02.97 gals)
Various Combo-Nations
36.88 lbs = Driver's seat + Lumbar support
34.00 lbs = FRONT & REAR bumper reinforcement & hardware
28.70 lbs = KOSEI K1-TS Aluminum wheel + 195/65/14" DURATION Tempra
28.22 lbs = KOSEI K1-TS Aluminum wheel + 205/55/14" NITTO 555R DRAG radial
24.30 lbs = KOSEI K1-TS Aluminum wheel + 175/65/14"
[Edited on 4/18/2013 by alfradio]
