 Pages:  1    3    5  ..  11
Author: Subject: Corolla Brake swap
1991tercelasdf
Mood: shes a squirter
[*] posted on 13-9-2007 at 03:32 PM
i said maybe a wheel spacer behind the rotor, but isn't that unsafe?
im back with tercel #7!
'94 tercel
5efte/5spd
megasquirt
aasco flywheel/ACT stage 2 6 puck clutch
STAGG struts w/ Custom rate Ground Control coils
195/50-15 Dunlop Direzza DZ-102 on 15" steelies
[*] posted on 13-9-2007 at 03:48 PM
Not if there is enough threads to hold the wheel on and the spacer is machined nice and flat so the rotor sits parallel to the hub and doesn't create vibration.
[*] posted on 13-9-2007 at 04:38 PM
he only needs a few mm tops
why don't we try throwing on a few washers behind the rotor, just to see if that clears everything, then you'll know if you need a spacer or not
josemata16
[*] posted on 13-9-2007 at 06:10 PM
According to Brembo plans, the differences in width that may been scraping into to the caliper is about 3 mm that may be gained by the spacer.
When yo full open the caliper and install in the tercel wich side of the caliper is in contac with the pad?
[*] posted on 13-9-2007 at 09:43 PM
Originally posted by Daox
What about shimming it out?
What is needed is the PCD section of the stock rotor to be machined with a half inch thickness. This is placed on the hub and then the Corolla disc goes over this spacer. It has been done with the Levin superstrut brakes and there are pics of this conversion on Rory's site: http://www.hardcore.ep91.com
[*] posted on 13-9-2007 at 10:07 PM
the part of the caliper that goes right behind the rotor, & bolts to the spindle/bracket
it could prolly be filled down a little....
[*] posted on 14-9-2007 at 09:58 AM
Keeble just bumped this on the TN forums. It is quite good info.
http://toyotanation.com/forum/t155043.html
1991tercelasdf
[*] posted on 14-9-2007 at 11:26 AM
nice thread daox, i might just try spacing the corolla rotor and if that doesn't work then just use paseo rotors and hope that my brake pads don't fall out.-dunce-
'94 tercel
5efte/5spd
megasquirt
josemata16
[*] posted on 15-9-2007 at 10:35 AM
What about using whashers on the brakets adjustment like this:
http://club-fiesta.net/nuevoforo/index.php?PHPSESSID=693d3e4e30cece...
It`s from a Ford Fiesta, but i think it could work. isnt`it?
Best Regards
[*] posted on 19-9-2007 at 08:31 AM
That could work, but I'd be very careful about what washers your using. I'd definitly recommend a hardened and ground washer versus just a hardware store stamped washer. We're talking about a very critical part of the car here. Definitly not the place to do a hack job on.
Spart
Mood: Learninating
[*] posted on 25-10-2007 at 08:24 PM
How about a steel plate that sits in between the knuckle and the caliper bracket?
How thick do you guys think it would need to be? There's a place around here that has a laser cutter, I know some people that work there and they let them cut/fab personal stuff on their free time.
1/8" enough? or 3/16"?
96 Tercel - Green
Current -15\" Black Konig Heliums, Whiteline F & R Sway Bars, Ksport Kontrol Pro Coilovers, Paseo Front Brake Conversion, New Headlights & Tails, Upgraded Sound System, Lots of Wax
Soon - Starlet GT Rear Disc Conversion, Lower Rate Rear Springs
Spart
Mood: Learninating
[*] posted on 25-10-2007 at 08:33 PM
Never mind, the plate would have to be between the caliper bracket and the caliper. So a one-piece spacer is out. Still leaves room for a two-piece spacer between the caliper and bracket, provided the caliper bracket itself doesn't rub the rotor when installed on the knuckle.
Or if the caliper bracket has enough extra material, the face that bolts to the knuckle could be machined.
I'm pretty interested in doing this and doing it in a fashion that won't get me killed because my calipers snap off...so input is WELCOME.
96 Tercel - Green
1991tercelasdf
[*] posted on 26-10-2007 at 08:53 AM
all you need is:
corolla caliper and bracket
corolla pads
paseo rotor
done.
the bigger paseo rotor gives you more heat and fade resistance, and the larger corolla caliper gives you more clamping force.
do this plus a rear disc conversion, and it should stop like you hit a wall.
'94 tercel
5efte/5spd
megasquirt
iced_mugg
Mood: gettin it goin
[*] posted on 26-10-2007 at 01:02 PM
also, not in addition to larger diameter, dont forget that the thickness of the rotor is more important than diameter, diameter is only leverage, while thickness is dissipation of heat
just thought id throw that in lol this is a good thread
1991tercelasdf
[*] posted on 26-10-2007 at 01:42 PM
for an additional upgrade, get drilled or slotted paseo rotors.
'94 tercel
5efte/5spd
megasquirt
 Pages:  1    3    5  ..  11
