Pages:
1
2
3
4
11 |
Courtesy of Chris (Boosted on Austarletclub)
MR2 Spyder front discs from DBA part number DBA753
255mm tall, 20mm disc width, 43.25 overall width, 55mm bore 4 X 100 PCD (http://www.dba.com.au)
Must be used with these calipers & custom mounts, factory calipers will not work:
Wilwood Powerlite 4 piston calipers for use with 20-22mm wide discs, need the 1.38inch bore model.
Levin superstrut brakes very rare and hard to come by check http://www.hardcore.ep91.com. Rory provides pics and the modifications necessary to fit these to the Terc/Seo
the corolla rotors would be a nice upgrade, the larger lever-arm would have more braking power, while the increased diameter & width would handle
track day heat with ease on a little terc
& how many/what size piston does the corolla have...?
starletparts
Mood: Always here to help ...
Three inherent issues exist in the starlet/paseo/tercel braking systems when looking to performance:
- Choice of friction compound on pad
- Choice of brake fluid
- Ability for brake master cylinder to flex off the firewall under heavier braking.
Running huge discs or multi-piston calipers are definitely not required to address the issues above.
You will actually save yourself a lot of coin addressing the fundamentals of braking.
On our track car we aren't running big brake kits or multi-piston calipers yet we still pull up on a dime and outbrake many other cars in our
class.
Cheers,
PB.
1991tercelasdf
Mood: shes a squirter
the corolla brackets bolt right on, i have pics to prove it.
im back with tercel #7!
'94 tercel
5efte/5spd
megasquirt
aasco flywheel/ACT stage 2 6 puck clutch
STAGG struts w/ Custom rate Ground Control coils
195/50-15 Dunlop Direzza DZ-102 on 15" steelies
The brackets bolt up, but what about the discs lining up with the calilpers?
ugabuga
wasnt someone making brake cylinder braces for LHD starlets/paseo/tercel?
i'd like to get one see if it makes a difference.
braided brake lines definitely do.
2004 Mazda Rx-8 (6 speed) - stock
i'm going to try to get austins pics uploaded tonight
1991tercelasdf
i am going to fully install the corolla brakes tonight, and see if there is any clearance issues, but i think they will fit fine.
'94 tercel
5efte/5spd
megasquirt
I look forward to it!
braided brake lines definitely do. |
To keep it short and not interrupt this thread I'll keep it simple and short. Yeah, I have one made. I fitted it to my Paseo once. It was very nice
and enhanced pedal feel a LOT. See the thread here:
http://board.tercelonline.com/viewthread.php?tid=30833
[Edited on 12-9-2007 by Daox]
josemata16
Thanks you all.
So you think that the LHD Tercel/Starlet/Paseo brake master cylinder could handle with the larger calipers without losing capabilities?
Thanks again
Best Regards
1991tercelasdf
this is not a completely direct swap.
the calipers and rotors fit, but the rotors rub somewhere, and i couldn't get a wheel to bolt on, not even the corolla wheel, without hitting the
caliper. there is a mounting depth issue between the hub and the caliper bracket, they are too close together.
this weekend i am going to get a complete coroola spindle/hub assembly from the junkyard and see if it will fit.
'94 tercel
5efte/5spd
megasquirt
the corolla wheel fit fine, the noise you heard was the backside of the rotor scraping on the caliper, like i said last night, the rotor needs to come
out a few mm, or maybe the corolla spindle mounts the caliper a hair farther back
What about shimming it out?
we are considering getting a corolla spindle to mess with from the junkyard, so his corolla is not comprimised, & torn completly apart
Pages:
1
2
3
4
11 |
