 Pages:  1    3  ..  11
Author: Subject: Corolla Brake swap
josemata16
[*] posted on 10-9-2007 at 07:51 PM
Corolla Brake swap
Hello
Have anybody tried to swap the AE-111 257 mm front brakes to a Tercel/Starlet? Could be done that with almost none modification?
I have understood that the Tercel / Starlet front discs are 239 mm in diameter, in vented and solid versions.
Also i found that the european AE-111 have the 257 mm diameter than the glanza, so i guess that are the same.
Thanks
Best Regards
Qballcious
Mood: Gonna have a garage soon!
[*] posted on 10-9-2007 at 07:54 PM
1st generation Paseo rotors are 254mm. Only 3mm smaller than the Corollas you mentioned. That has been the cheapest swap so far.
1998 Toyota Tercel CE, 2dr 5-speed \"Touring Edition\" ???
Qballcious
[*] posted on 10-9-2007 at 08:05 PM
According to Brembo, the largest front rotors the Corolla had in the USA was in 1993+94 @ 255mm. Only 1mm larger than the Paseo. But I wonder if the caliper bracket is the same. Reason I wonder is because there could be cheaper "big brake" kits available for that Corolla.-sly-
josemata16
[*] posted on 10-9-2007 at 09:06 PM
I have doubs with the differences between those discs, corolla discs are widers than the paseo brakes, so that`s why i`m not very sure about the swap.
Thanks for yours aswers.
Qballcious
[*] posted on 10-9-2007 at 09:22 PM
Good point. wonder if the corolla calipers and mounts would bolt onto a Tercel if also using the corolla rotors. Doesn't Alf's GF have a corolla of that year range? might need to test this out....
Paseo 18mm (17mm min)
Corolla 22mm (20mm min)
tatothug
Mood: 14.55secs
[*] posted on 11-9-2007 at 12:16 AM
what car has the same size disc as the 1st gen paseo's?
1991tercelasdf
Mood: shes a squirter
[*] posted on 11-9-2007 at 01:23 PM
i just got a 96 corolla i could mess with...
im back with tercel #7!
'94 tercel
5efte/5spd
megasquirt
aasco flywheel/ACT stage 2 6 puck clutch
STAGG struts w/ Custom rate Ground Control coils
195/50-15 Dunlop Direzza DZ-102 on 15" steelies
EL42GPTurbo
Mood: Redeemed by the Blood
[*] posted on 11-9-2007 at 04:56 PM
quit wondering and try it!-saint-
sfljdmej2
[*] posted on 11-9-2007 at 06:17 PM
really would like to now how this comes out im intrested in an upgrade from the 239mm discs.
im bone stock for now.
Qballcious
[*] posted on 11-9-2007 at 07:27 PM
As mentioned before a set of 92-95 Paseo rotors and caliper brackets is a bolt-on upgrade for a Tercel. I did the swap and it made a HUGE difference. One wouldn't think going from 238mm to 254mm rotors would make that big a difference, but it did.
I can only imagine how awsome larger ones would be.
tr0ublemaker03
Mood: hungry
[*] posted on 11-9-2007 at 07:28 PM
1991tercelasdf just called me, 96 corolla brakes bolt right up....
Qballcious
[*] posted on 11-9-2007 at 07:47 PM
1996 Corolla = 255mm x 22mm according to Brembo
Qballcious
[*] posted on 11-9-2007 at 07:48 PM
can you elaborate by bolt on? do the calipers/brackets also fit?
josemata16
[*] posted on 11-9-2007 at 08:11 PM
As a comparative information
EP-90 /EP 80 Starlet /EL44 Tercel O.D 226mm /Total wide from hub contact line 36.5 mm /Thk 11mm (Solid Discs)
EP-91 Starlet/EL-5X Tercel O.D. 238 mm / Total wide from hub contact line 37.7 mm / Thk 18mm(Vented Discs)
EP-91 Glanza/Paseos O.D. 254 mm / Total wide from hub contact line 37.7 mm / Thk 18mm(Vented Discs)
AE-101/AE-111 Corolla O.D. 255 mm / Total wide from hub contact line 42.1 mm / Thk 22mm(Vented Discs)
I think that the space occupied by the wider discs (about 3mm) can be given by a couple of washers in hte brackets bolts. My biggest doubt is if the brackets from the corolla will fit in the hub of my EP-90 Starlet.
Because i`m living in a crazy country, the starlet`s solids discs are more expensives than the corolla`s ones. And i could find a corolla`s drilled and sloted discs in about the half of the price. Crazy isn`t it?
I`ll start to look for the calipers and brackets. If i find any other information i`ll post it.
Thanks for your answers
Best Regards
josemata16
[*] posted on 11-9-2007 at 08:24 PM
Oh i forget it
The 1st gen pase have the same 238mm dics.
As a general info:
I asked the same questions on ep-91.com and they recommended my to swap the AE-101/AE-111 Levin GTZ superstruts front brakes that have and O.D. of 280mm and they said that is a straight fit. Here i can`t find these pieces, buy if any of you find it useful there is the info:
http://www.ep91.com/showthread.php?t=48
Thanks you all again.
I?ll try the swap and post the pics as soon i find the pieces.
 Pages:  1    3  ..  11
