 Pages:  1    3  4
Author: Subject: URETHANE control arm bushings. All sorted out !
[*] posted on 3-5-2008 at 02:42 AM
done... i'll prune it later for useful info...
[*] posted on 3-6-2008 at 07:34 AM
http://www.toyheadauto.com/PerformancePages/Polyurethane_Bushings.h...
ugabuga
[*] posted on 3-6-2008 at 08:34 AM
toyhead auto is one of the people that you can get it through.
Turbotrix in Edison NJ is also a distributor but it seems the company that makes the ... forget the name ... australian company is really backed up or something so they are not taking new orders since it will be a few months by the time you get your bushings.
2004 Mazda Rx-8 (6 speed) - stock
[*] posted on 26-6-2008 at 11:55 AM
ok, i'm about to order some poly bushing, but the info/part# at toyheadauto.com don't match the ones we have here on pg.1...
they have:
Paseo
EL44 / EL54 6/1991 – 07/1999
Front Control Arm Lower – Inner Front Bushing-1905K - (4 bushings,2 tubes) Must Measure, 31mm OD bushing $37.19
Front Control Arm Lower – Inner Front Bushing-1888K - (4 bushings,2 tubes) Must Measure, 34mm OD bushing $38.16
Front Control Arm Lower – Inner Rear Bushing-1906K - (2 bushings)”Don’t remove OE tube from arm”50mm long mount bracket $26.75
WTH...?
i'mna order from optionsautosalon, as i can get them a bit cheaper...
--- steven
[*] posted on 18-7-2008 at 11:32 PM
i found my Super-Pro polyurethane bushing kit packages that i used on my '95 tercel... i used SPF1888K, & i had to shave the bushings down ~2mm to press fit them into the control arms...
i'm going to be ordering a bunch of bushings to confirm it... i have new Paseo front control arms, & i'mna measure the bushing before i order...
i think the info in this thread is incorrect...
for the 91+ Tercel/Paseo front control arms, the part #'s are SPF1905K for the front bushings, & SPF1906K for the rear bushings... for the EL31 chassis tercel, use the SPF1988K & SPF1906K combination...
--- steven
T.Hawk
[*] posted on 5-9-2008 at 10:28 PM
so now the question is can us tercel guys get ahold of urethane engine and transmission mounts!!
[*] posted on 5-9-2008 at 10:57 PM
They are in production somewhere, because guys here have'em and I have a rear one coming from GT-REVVA.
Paseo15psi
Mood: 1st & 2nd Gen Paseo goodness
[*] posted on 6-9-2008 at 07:22 AM
http://www.ToyTuning.com and it looks like it would be prudent to just buy new suspension parts and then do this mod. I forgot about this thread.
[*] posted on 27-10-2008 at 06:48 AM
i guess i better measure my shit before ordering...these don't require a press to change them do they??
[*] posted on 28-10-2008 at 04:14 AM
--- steven
the front bushing needs to be pressed in, but the rear bushing is easier...
[*] posted on 28-10-2008 at 06:21 AM
grr, ok :blah:
[*] posted on 28-10-2008 at 01:54 PM
if it makes ya feel better, we just used a bench vise to press them in... it's not too hard...
Pierros
[*] posted on 15-11-2009 at 06:46 PM
Hey guys, I'm about to change my front bushes on my Second Gen (96+) EL54 Paseo and I wanted to go with Super Pro, but after checking their site and my local dealer I ended up having the same problem... which kit is right?
SPF1905K 31mm OD bush
or
SPF1888K 34mm OD bush
And making things even more confusing I found this link from Tein USA that is an official Super Pro distributor and clearly states:
SPF1888K TOYOTA PASEO EL44 91-11/95 FR $41.00 (but this for the 1st gen only I guess)
SPF1905K TOYOTA STARLET3/96-9/99 FRONT $53.00
Tein (SuperPro Catalogue)
Has anyone a 100% answer which kit is the correct one?? :dunno:
[Edited on 15-11-2009 by Pierros]
Pierros
[*] posted on 23-11-2009 at 08:33 AM
Finally I got mine fitted and it was the SPF1905K 31mm bush
[*] posted on 4-5-2010 at 02:33 PM
Any more updates? On people that have these installed.
 Pages:  1    3  4
