| Pages: 1 2 3 .. 5 |
Qballcious
Mood: Gonna have a garage soon!
posted on 4-4-2005 at 07:41 PM |
Starlet GT EP82 / EP91 rear disc brake conversion for Tercel/Paseo HOW-TO (56K ye be warned)
I spent all winter hoarding performance goodies for the Terc. I finally had one free day and awsome weather so I decided to start modding -sly-
I took lots of pics so here's a DIY Qball style...
Before you start. Put the transmission in 1st gear if it's Manual. Make sure it's in "park" if it's an automatic. I had my
Terc on 4 jackstands so I did none of that.
Jack up the back of the car using the factory lift points on the rocker panels and then place jack-stands under the rear axle. Now remove the
wheel.
Let's get down to business.
This is the little nasty rusty drum brake setup Toyota equiped our Tercels with. Although completly adequate for the weight of the vehicle, it just
looks plain fugly when you've got some sweet alloys on your ride.
Start by removing the dust cover using a flat-head screwdriver/chisel and a hammer. Tap the cap alternating sides to pop it off.
Now you'll see the cotterpin and nut retainer. Remove the pin using a set of needle-nose pliers to straighten the pin legs and then pull it out.
The nut retainer should come right off after the pin has been removed.
Now remove the nut with a 22mm socket. Both sides of the car use regular thread. No reverse threads here. So "righty-tighty, lefty-loosy"
applies here too.:D
Remove the washer.
The bearing should now come out easily.
After the bearing has been removed the drum should come off. There may be some hesitation. If you need better leverage, try putting the wheel back on
with a couple of lugnuts and use it for leverage. There is also an adjuster inside the drum brake assembly that can be accessed through a hole in the
backing plate which is plugged with a rubber grommet. Release the shoes like that if you just can't get the drum off otherwise. Older drums
usually have lips worn into the drum which makes them harder to remove.
This is what you should be looking at after removing the drum.
Remove the giant retractor spring by prying it off with a screwdriver or do like I did and use your hands. It's really not all that stiff.
It's function is to retract the brake shoes when you let off the brake pedal.
Next you need to remove the retaining pins. These hold the brake shoes in place. There's one in each shoe. Reach around back with one hand and
hold the pin in place. Then with the other hand, push the front washer in and twist to release the washer. Now remove the pin, spring and both
washers.
You should be able to remove the shoes one at a time.
Remember not to lose the bottom spring that connects the two shoes.
Now remove the e-brake cable. Just pull the spring back with your hand and slip the cable out of the bracket.
Release the e-brake cable from the backing plate by removing the two little bolts with a 10mm socket.
Now it's time to get under the car and unbolt the solid brake line from the axle. A standard open-end wrench will most likely strip the nut so
use a linewrench. This is a special wrench that has more contact surface than an open ended wrench which will protect the nut and allow you to loosen
even the most stubborn nut. It's like a box-ended wrench with a slot in it to slip over the pipe.
Now unbolt the backing plate from the axle by removing the 4 bolts with a 14mm socket.
It's now time to prep the Starlet GT disc rotors. I know it's really rusty but I love it :D
Remove the old inner bearing seal with this wicked seal puller.
That seal puller looks like a weapon you say? Well I'd have to agree:mad:
After pulling the old seal. The bearing comes right out.
Let's hit the parts washer for some cleanup. You can tell I love this part....mmm....solvent -lol-
Clean the bearing out well and then blow it out with compressed air. You want to get ALL the old grease out.
Do the same for the rotor.
So fresh and so clean-lean-lean...sorry....anyways - back at the ranch...
Repack the bearings with wheel bearing grease. I do it manually but you can use a bearing packer. You can use either the Tercel or Starlet bearings.
But I prefer to use the Starlet bearings since the race is installed in the rotor already. Make sure to put some grease in the cavity of the rotor too
to make sure the bearings will always have grease.
Now it's time to re-install a new Genuine Toyota Japanese built inner bearing seal. Again the USDM/CDM 91-99 Tercel seals fit the Starlet GT
rotors.
I didn't get a pic of the seal driver I used so here's what it looks like on top of the old drums. Use it to pound the new seal in nice and
straight. Apply some wheel grease to inside of the seal to protect it later during sintallation.
Now that the rotors are preped it's time to go back to the axle. Clean off the flat mating surface with a wire brush and sand paper. Then cover
it with anti-cease just in case you ever need to remove it in the future.
Bolt on the new backing plate with the longer bolts from the starlet GT setup. The Tercel bolts are too short.
Coat the spindel with some more axle/wheel grease to protect the seal during installation.
Slide the rotor onto the spindel and re-install the newly re-packed outter bearing, washer, nut, nut retainer, cotter pin, and dust cap. All those
parts can be used from either your Tercel or the Starlet. They are all interchangable.
Bolt the caliper bracket to the backing plate. 12mm wrench. Now's also a good time to clean the rotors off with some aerosol brake cleaner to get
all the grease and solvent off before installing new pads.
Open up one of your boxes of brand new Genuine Toyota pads. -sly-
Install the pad shims. Again..rusty I know.-love-
Use some anti-squeek and apply it to the contact patch of the shims.
Time to prep the caliper. I had already rebuilt these but I had a couple of pieces left. Copper washers for the flexible brake hose.
Make sure to retract and rotate the piston into this position before bolting the caliper to the bracket. The little bumps/tabs on the brake pads have
to fit into that slot in the piston to keep it from rotating. So make sure it's installed properly.
Now snap the other end of the hose in place on the bracket with the C-pin.
Attach the hard line from the Starlet setup. The Tercel line doesn't fit. You may be able to bend it to fit but if you have the Starlet lines,
use them. IF you don't want to wreck your Tercel setup, then go out and buy some hard lines with connectors and bend it to suit your needs. They
cost less than $10 each.
that's sexy.
Ok when you're done admiring your own work it's time to get messy again. Time to hook up the Starlet GT e-brake cables. I won't sugar
coat it. This part suxorz.-blah-
You have to remove the aluminum exhaust heat shield to get at the e-brake cables.
You're gonna have to make some room to work in there so unhook the rear muffler hanger and slide the whole exhaust off to either side.
Then using a large drilbit to drill out the 3 aluminum rivets that hold the shield in place. Don't worry. You can re-install it later.
Now get in the car and take your 10mm socket, extenssion and ratchet with you. Loosen the adjustor nut as far as you can without backing it off the
bolt all together.
Get back under the car and remove the cables with a 10mm socket.
Now you'll run into a problem. At least I did on my 98 Tercel.
Starlet cable on the left - Tercel cable on the right.
I had to fab up some sleeves out of a piece of 10mm conduit to solve the problem.
MINT!!!!
Unfortunatly the Starlet is a little shorter than a Tercel so it's cables too are a little shorter than the Tercel's. So you can only use
one mounting point on each side.
Route the cable through the stock location on the axle. You will have to remove the grommet and then pass the cable through the hole. Reinstall the
grommet over the cable and squeeze it back into the hole.
I didn't get any pins to attach the cables to the rear calipers so I had to make some. I used some TOYOTA bolts that I had lying around. I cut
them to length and drilled them for a cotter pin.
Now that you're done with the cables you can re-install the heat shields using some standard aluminum pop-rivets.
Go back into the cab and tighten that e-brake tentioner nut.
That's it. You're done. Now just bleed the brakes and top off the brake fluid. Put the wheels back on and you're ready for a test run.
BTW this setup will fit with 13" stock wheels.
Good luck guys -ccolguy-
[Edited on 5-4-2005 by Qballcious]
1998 Toyota Tercel CE, 2dr 5-speed \"Touring Edition\" ???
rice
Mood: ohhhhnoes!!1!!!
posted on 4-4-2005 at 07:49 PM |
this is a great diy-shock-
sticky!!!!
| Quote: | Originally posted by BFDeihl
\"Best\" is subjective.
\"Cheapest\" depends on your parts connection.
\"Easiest\" depends on what you are used to and the facilities you have to fabricate custom pieces. |
holla holla holla holla holla holla holla holla holla holla holla holla holla holla
ranterc
posted on 4-4-2005 at 07:50 PM |
-dumass-
nice job -coolguy-
ranterc
posted on 4-4-2005 at 08:02 PM |
oh , almost forgot to ask how was your test drive ?how noticalbe was the difference in braking power?
Qballcious
posted on 4-4-2005 at 08:04 PM |
| Quote: | Originally posted by ranterc
oh , almost forgot to ask how was your test drive ?how noticalbe was the difference in braking power? |
It's not insure for road use right now. I will take it on the road test in about a week after I get back from North Carolina.
eviilboy
Mood: SLOW4DR
posted on 4-4-2005 at 08:19 PM |
I want pictures of the sexiness with everything put back on.
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety. -- Benjamin Franklin
ugabuga
posted on 4-4-2005 at 09:31 PM |
qball remember that the pads have a breakin period of a couple of hundred miles during which you shouldnt get them white hot :)
Walkman5410
Mood: Race your Race Car
posted on 4-4-2005 at 10:34 PM |
Dang dude you got lucky like 4 times with that customize stuff you do....and that stuff you have laying around..im jealious lol
nice setup dude
ShowCarTercel
TO Patron*
Mood: I need more space and a garage.
posted on 5-4-2005 at 07:14 PM |
Wow, you made it look so easy. Awesome DIY QBall.
Damn, I just had my rear brakes machined last October. Guess I will just have to drive with the e-brake on for a while to speed up the wearing out so
I can replace them.-banana- I was rear disc brakes now.
That's Manitoba's First and Only 5efhe.
It's Actually On The Road.
djsilent
Mood: tercelclub.org
posted on 5-4-2005 at 07:38 PM |
VERY nice writeup, I just have a couple questions.
1. Is there no need for the starlet rear axle? You can put it on the stock tercel axle? That wouls save a bunch of money and time...
2. Why did you switch the ebrake cables? Why won't the tercel ones work? Instead of fabbing up something to make the starlet cables work,
couldn't you shave the other end of the tercel one or modify it to fit the starlet calipers?
Once again, great writeup. I just want to clarify a couple things before I start acquiring parts.
Qballcious
posted on 5-4-2005 at 07:57 PM |
| Quote: | Originally posted by djsilent
Once again, great writeup. I just want to clarify a couple things before I start acquiring parts. |
great questions.
A#1 - You can add the starlet disc setup to any 87+ Tercel or 92+ Paseo rear axle. No need for the starlet axle unless you want a shorter axle and
better chamber. Then get the Starlet axle.
A#2 - The Tercel cable doesn't fit the calipers. The calipers require a looped end. You could modify the Tercel cable to work by machining the
aluminum stop to fit the acliper. Then weld a u-chacle to the end in order to make it fit the caliper. I already bought the Starlet cables and naivly
assumed they'd fit because nobody had ever mentioned and incompatibility before.
Qballcious
posted on 5-4-2005 at 08:34 PM |
| Quote: | Originally posted by eviilboy
I want pictures of the sexiness with everything put back on. |
ask and ye shall recieve -banana-
mikeyy
posted on 5-4-2005 at 08:36 PM |
u have ur OWN cleaner station -coolguy-
Qballcious
posted on 5-4-2005 at 08:57 PM |
Pretty much all the tools are my pop's. He's a lifelong mechanic/machinist so he's got pretty much every tool you'd ever want.
except a welder cause you can't weld indoors in the winter -lol- no garage -lol- wait... -irked-
cmack
Mood: $28.75/hr :D wooohoooo!!
posted on 6-4-2005 at 05:06 PM |
nice DIY!! -banana-
rims with rear discs -boring--boring--boring--boring--boring--boring--boring--boring--boring--boring--boring--boring-
90 Toyota Tercel Auto RIP 2005
91 Nissan NX1600 5spd GA16DE(T) Lots of modifications
July 26/07 13.14@102.19mph dynoed 207hp 220tq
i loved my toyota, but i love my nissan too!  :D
| Pages: 1 2 3 .. 5 |
